How do I take these two pieces off?
Im trying to take out the carpet and the only thing holding me back is that the carpet connects directly behind cig lighter and ash tray, underneath what looks like a hard drive to me. If I don't have to take these side pieces off it to take the carpet out please let me know!.
I have to change the padding because I suffered some slight flood damage. crap stinks.
I have some pics to demonstrate.
and one to see how nasty it is
Yes...The Hard Drive. I think I read somewhere that you can get an adapter that will let you hook up your Play Station and allow you to drive the car "by wire". Sorta like a jet fighter.
Did you know that that hard drive records all your driving parameters. Like if you're speeding...not that anyone here ever does.... or swerving around corners... or locking up your brakes....and reports it back to your insurance company on a cell frequency!!!
Sorry man.... I couldnt help myself!!!
Thats actually the Engine Computer...ECU. You don't want that lil gem damaged!
Did it get wet when the car got flooded?
For the carpet... When I did my sound system I got about as far as you did in your pics cause I wanted to dynamat and pad the floor. I realized the entire lower dash had to come out and I was tight on time and left it.
Damn man I think I will just cut about 4 inches and I think it will set it free...what do you think? can you think of any potential problems?
Nah the water just reached the carpet..but almost up into the seats ...I had to move it while it was pouring. my damn street floods like the rio grande
That was close... That ECU will run you over $500 at the dealer to replace. Auto salvage places charge $100-$300 or so. And thats if you can find the correct service number.
I wouldn't cut it ... especially there. You'll likely end up with it pulling away and tying up your gas pedal. Can you say WOT!
Take the time and many many Advil ( your back is gunna hurt tomorrow, but please do follow the label instructions!) to get that center dash section out of your way. Then you can access the ECU and everything else down in there much easier. I believe the Transmission controlller is there if you have an auto, I know you're 5sp, and the climate control module as well.
Its pretty tight in there and I wouldn't want to be hacking away with a knife and slice a main harness!
I think all ECU's in Houston aught to be vacuum sealed in heavy plastic.... Hmmmm maybe a product opportunity in that. Too many good cars get screwed up because the city was too damn cheap to put in the correct size sewer pipes when they did the job.
Originally Posted by volkl77
damn thanks <3
Start there. That will gut the entire center of the dash and you should be able to see where you need to go next to get the rest of it out. It will look like this when you are done
http://memimage.cardomain.com/member...59_57_full.jpg
CRAp.... Just looked at my car. You are not getting that center section out unless its different than my 96. The WHOLE dash including the center is one piece. I thought for some reason the dash splt along the line formed by the passenger air bag. It doesn't.
Still get the stereo, a/c control, ash tray, and vents/emergency/defog panel out of the way and you'll have better access to the ECU and other contollers in there.
I'll look for and ECU removal link for you.
Originally Posted by PhaZe
Im trying to take out the carpet and the only thing holding me back is that the carpet connects directly behind cig lighter and ash tray, underneath what looks like a hard drive to me. If I don't have to take these side pieces off it to take the carpet out please let me know!.[/IMG]
Thought about this all night.
The cutting option seems like the only practical one.
Putting it back to gether is the real problem.
You could get some heavy carpet thread and stitch it together ..a lot of work... Or try Home Depot or Lowes and look for the reallly realllllly sticky carpet tape. The stuff with the reinforcing fibers in it, and brown paper backing. You'll know it when you see it. The roll is all lumpy because the adhesive is so thick. I doubt this stuff will ever let go.
Best I can do here
Best I can do here
REDinLV
Aug 15, 2024 12:30 AM
