replacing power steering belt
Old Jun 26, 2004 | 06:20 PM
Corey_25's Avatar
my belts have plenty of tension but are still squeeling when cold. they are pretty badly cracked so I think I will replace both.
Is the power steering belt hard to get access to or hard to get off?
Old Jun 27, 2004 | 04:08 AM
twiggy144's Avatar
Best technique for the PS belt: cut the old belt off. Wrap the new belt over both pulleys, as you would get a bicycle chain back on the sprockets. This way no bolts to slack.
Old Jun 27, 2004 | 05:45 AM
Corey_25's Avatar
Will I have to remove anything to get the new one on?
Also, is there anything tricky about replacing the other belt?
Old Jun 28, 2004 | 12:02 PM
twiggy144's Avatar
the other belt (alternator, a/c) will have to be removed first. This one is easier. Slack the tensionner pulley, slack the tensionner adjusting bracket itself , slide the pulley to slack the a/c-alt belt. Remove belt very easily. Installation is reverse.`
check out this thread going on http://forums.maxima.org/showthread.php?t=320355
tsi6001
Oct 3, 2022 10:23 PM
vingodine
45
May 21, 2016 12:46 PM
02PearlSE
Oct 7, 2015 02:12 AM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
