Just bought my 97 se
Old Mar 31, 2001 | 09:58 AM
hash's Avatar
hello I just bought an 1997 se yesterday and would like some information plese. Do they make clear lenses for the amber turn signals in the front and if so are they made by apc. Also what brand aftermarket stuff is the best for nissan this is my first nissan also have a 2000 v6 accord. I am also experienceing a loud rattle in the sun roof can anyone avise as to what the hell it is.
Old Mar 31, 2001 | 10:05 AM
Sprint's Avatar
Congratulations.. and welcome
yes they do make clear lenses.. best place to find them for sale is Ebay...
Aftermarket stuff.. this will depend on what mod you are doing..
have a look here:
https://maxima.org/maxfaqs/index.shtml
and here:
http://web2.airmail.net/scutchen/max_faq/
it will answer most of the questions you wish to be answered
is the rattle while open? or while opening?
Old Mar 31, 2001 | 10:26 AM
Jimbo
rattles?
Get use to rattles. The interior of my '98 is one big rattle. Just buy some foam weatherstripping, or similar product, and just start stuffing areas were you think there are rattles. I usually try and apply pressure to areas that I think are causing rattles. If the rattle stops when you push on an area, try to place foam or some sort of shim to try and 'sure' up the area. Or, do what I do sometimes - just turn up the radio and try to forget that Nissan build quality isn't that good.
Old Mar 31, 2001 | 11:00 PM
dwapenyi's Avatar
Ahhhhh, the sunroof rattle. I think you'll find that it is the spring loaded wind deflector. When the roof is open put your hand thru and grab the front edge of the opening. Your hand should be on the deflector, hold it and see if the rattle stops. I removed mine completely and I'm eventually adding a wind deflector on top of the car.
DW
Old Mar 31, 2001 | 11:34 PM
MaxedOut97SE
Re: rattles?
What are you guys talking about? Thet build quality is great in a Maxima. I mean, I don't drive your car, but the build quality and fit and finish in my car is excellent. Hell, my car is 4 years old with 63K miles and the interior still looks new. I'm a very picky person and rattles drive me absolutely CRAZY!!!(used to drive Ford Taurus SHO, go figure.....)However, with the Max, I couldn't find a rattle even if I tried. The leather looks as good as it did when it was driven off the lot. The interior even still has that new car smell!(no lie!) Sorry it's bad for you guys!
Old Apr 1, 2001 | 04:55 AM
TommyBoiSxty9
Re: Re: rattles?
I've heard a LOT of people complain about rattles on these cars...
even the 5th Gen.... like the windshield pillars and somewhere behind/near the radio
Old Apr 1, 2001 | 03:19 PM
hash's Avatar
[QUOTE]Originally posted by dwapenyi
[B]Ahhhhh, the sunroof rattle. I think you'll find that it is the spring loaded wind deflector. When the roof is open put your hand thru and grab the front edge of the opening. Your hand should be on the deflector, hold it and see if the rattle stops. I removed mine completely and I'm eventually adding a wind deflector on top of the car.
DW
thanks for the reply everyone...By the spring loaded wind deflector thats the one on the inside right? the cover that you can pull to close the sun roof?...It is really load when I drive.....just rattles when its open or closed. And it doesn't seen to have anything to do with the actual sunroof I don't think. Is there anyway to fix this or is taking out the indise cover my only option.. I have an outside deflector.
Old Apr 1, 2001 | 07:03 PM
metallic97gxe's Avatar
Master Will
rattles....
come you guys and you loud bass 10's and 12' woofers pumpin the mad bass....bass is good....I have mods on my page here
http://members.cardomain.com/williamg
Old Apr 1, 2001 | 07:39 PM
VinnyD's Avatar
Rattle
Outside sunroof deflector, probably loose, mine did that and i tightened it down....dont rattle anymore...actually mine didnt rattle til a bird hit it, but thats a different story...
Old Apr 2, 2001 | 06:07 AM
dwapenyi's Avatar
Yeah, it's on the inside front. It's not the cover you can pull closed. It a black steel bar that goes left to right across the front inside of the sunroof. Mine rattled when closed, banging up against the sunroof. If you hold it while driving over bumps, your rattles should disappear.
DW
thanks for the reply everyone...By the spring loaded wind deflector thats the one on the inside right? the cover that you can pull to close the sun roof?...It is really load when I drive.....just rattles when its open or closed. And it doesn't seen to have anything to do with the actual sunroof I don't think. Is there anyway to fix this or is taking out the indise cover my only option.. I have an outside deflector. [/B]
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
