strange noise, any thoughts?
Old Jun 28, 2004 | 11:19 AM
fast97maxse's Avatar
97 MAx, 61k miles now makes a kind of "groaning" grinding noise.
Sounds real bad, but doesn't seem to affect performance.
It comes from the front right (passenger) and is speed related
- it sounds faster the faster I go. Sometimes it sounds really bad, others it's hardly there (but never gone completely).
I took it to a local garage and they checked the brakes and he had it up on the lift, saw some loose plastic in the wheel well with a rub mark and put it tight with a zip-tie - but after it occured to me that coudn't be it as the noise happens in a straight line, not just at full lock. And it still makes the noise...
So what do you think it is?
Wheel bearing(s)?
Brake pad? (I had new pads/rotors put in a few thousand back, but the noise only started a little while ago.)
Thanks in advance...
Old Jun 28, 2004 | 11:21 AM
|Bijan|'s Avatar
UCF Lexus
Does it get worse when you turn one way and less when you turn the other? If so it's probly your hub bearing on the passenger side. They're notorious for going out
Old Jun 28, 2004 | 11:29 AM
nahh, doesn't seem to be worse straight or turning in either direction.
Can't figure out why its worse somtimes than others.
I thought humidity at first, but that doesn't seem the cause.
What's a hub bearing cost to repalce?
How hard is it to do yourself?
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
