CEL!! If you have a 0705 and/or 0903, check this info:
Old Jun 29, 2004 | 11:25 AM
phenryiv1's Avatar
Mod her. Ate her.
https://maxima.org/forums/showthread...85#post3055185
I know that there are a LOT of links there, but I searched as best as I could. There are no difinitive answers (partially based on the nature of the "jackpot" code), but there is some information that you can use to self-diagnose.
If you have any info or contributions, please post them here. Questions welcome.
Old Jun 29, 2004 | 12:07 PM
XoPtOn's Avatar
i had the code 0705 but then i reset it and the light hasnt turn on yet, is it supposed to turn on?
Old Jun 29, 2004 | 12:11 PM
phenryiv1's Avatar
Mod her. Ate her.
Sometimes you get a ghost code that stays off when reset, but typically the code will return if the problem is not fixed.
Old Jun 29, 2004 | 12:24 PM
MaxedOutOfCash's Avatar
Pizda Boy
i have the 0903 & still haven't found the problem.
Old Jun 29, 2004 | 04:38 PM
phenryiv1's Avatar
Mod her. Ate her.
For reference, do you mind posting what you have tried?
Old Jun 30, 2004 | 04:36 AM
Pizda Boy
sorry man...i got the 0111 code...i didn't think twice before I posted. 0111 is the "the jackpot code" . . .if you want me to post some things i checked on that, let me know...
Old Jun 30, 2004 | 05:32 AM
Gen8888's Avatar
I'm getting the 1008 Code which is the EVAP canister purge volume control valve. This code is setting off my knock sensor and BARO/MAP sensor as well. But after resetting the ECU, the Baro/Map has not come back, just the knock and the EVAP. I found out the part number for this so i hope this fixes the Code but I know its not the same part you guys are looking for. Goodluck with yours.
Old Jun 30, 2004 | 06:28 AM
Gen8888's Avatar
Quick questions. Do you guys know why my EVAP Canister Purge Volume Control Valve is metallic and others is plastic? Could it be that there is a difference between Cali-spec and Fed?
Andy
Old Jun 30, 2004 | 08:22 AM
phenryiv1's Avatar
Mod her. Ate her.
There are a few jackpot codes- go ahead and post your code and what has been tried.
Old Jun 30, 2004 | 08:23 AM
phenryiv1's Avatar
Mod her. Ate her.
Andy
I get all of the names of all of the components mixed up- which component are you referring to, and where is it located?
Old Jun 30, 2004 | 09:07 AM
Gen8888's Avatar
EVAP Canister Purge Volume Control Valve. If you start from the 3rd to last letter of the VIN number which is stamped into the firewall, it is 3-5 inches towards the radiator. It has 2 hoses and a electrical harness. It is the Valve in picture A from this site. http://www.jcn.net/mwest/evappage.htm
Old Jul 2, 2004 | 07:11 AM
phenryiv1's Avatar
Mod her. Ate her.
Oh, I was thinking that you were talking about the EVAP Canister Vent Control Valve, which is at the rear of the car...
Miket2006
Mar 1, 2021 03:55 AM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
MaxDD
Sep 24, 2015 06:40 AM
TheMafia
Sep 4, 2015 08:26 AM
