Where to tap into power for indiglo gauges?
Old Jul 6, 2004 | 10:22 AM
HybriDSM's Avatar
All the oh so detailed instructions say is to tap into thge power for the headlights. Where is the best place to do so? what wire colors? etc...
Old Jul 6, 2004 | 11:19 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
use the dimmer dial power. just tap into that one. when ever you put on the parking lamps the ingiglo gauges will show up.
Old Jul 6, 2004 | 05:55 PM
HybriDSM's Avatar
cool, ill check that out. Any other suggestions? Im gonna try and do this when I get off work at midnight tonight.
Old Jul 6, 2004 | 08:37 PM
HybriDSM's Avatar
bump
Old Jul 6, 2004 | 09:23 PM
Guttermouf5150's Avatar
well the parking lamps are on the red/green stripe wire at the headlight switch. i'm not sure if this is where you want to tap into or not, but they would come on when the parking lights come on. i'm not sure if they will dim or not though.
Old Jul 6, 2004 | 09:30 PM
happyricefob's Avatar
V^___^V
Okie. Now we have to hook up the power/ground to the control box. there should be a BLACK wire. that's ground. Using the wire stripper, strip about 1/2 inch of the insulation off and twist into a firm lead. Then, using the BACK of the gauge cluster, find something labeled "GND" that's ground. Unscrew that ground screw just enough to slide and wrap the ground wire around it, and then retighten.
For Power, that's gonna be tricky. We want the indiglos to come on ONLY when the lights are turned on. So. we're going to tap into the "DIMMER" switch. But not physically the dimmer switch, but the power that lights up the little Dimmer logo. get it? When you turn on the lights, the whole console and radio buttons turn on, right? so we're going to get power from that little logo that turns on when the lights are on. So for this car (97 SE) it was a blue wire. To make sure, use a voltmeter to see how much power is coming to that lead. CUT the blue wire, strip both ends and splice into it with the red wire from the control box. wrap it around a few times with electrical tape to make a secure and strong connection. Test the connection by turning on the lights. The gauges should go on. good.
credit: cheston
Old Jul 6, 2004 | 09:33 PM
i don't think you should cut the blue wire, just strip it back and splice the power wire into it. like wrap it around. then tape.
Old Jul 6, 2004 | 09:59 PM
killcrap's Avatar
if u want the ingiglo gauges to automaticlly turn on, you usuually have to press the button to turn them on sometimes. just double ground it to the gnd behind the tach. so its connected to the tach and fuel gauge
Old Jul 6, 2004 | 10:24 PM
HybriDSM's Avatar
Thanks for the replies guys!
what the hell are you talking about. they have to have 12v power from somewhere. they can't just be grounded.
Old Jul 7, 2004 | 02:47 AM
HybriDSM's Avatar
ok, i got everything on. Took me forever. The tach gauge face wasnt quite big enough to slip down over the back of the needle. had to force it over, and it wrinkled up and the face kept sticking on it, so I had to hack the **** out of it so that it would work. Looks kinds crappy, but not all that noticable. They were only $20 so if I have to get another set im not gonna cry about it. I sure hope that it still lights up even though I had to remove some material.
Miket2006
Mar 1, 2021 03:55 AM
leatherneck
Sep 30, 2015 09:16 PM
