A/C leak at pressure switch fittiing, how to fix?
Old Jul 7, 2004 | 06:05 AM
redoctobyr's Avatar
Hey guys. I have a '99 SE with 111k on it. Tried my A/C (which I hardly ever use) about 2 weeks ago, wasn't working. I hadn't used it since last summer sometime, and even then maybe twice during the summer. Had 0 psi on the low pressure side. Recharged it, and it worked. Then it leaked over a week to where the compressor wouldn't come on any more (had about 15-20 psi on the low side).
In looking it over, there is a leak coming from one of the hoses/pipes going into the top of the low/high pressure switch. The metal canister next to the radiator, near the battery. There are two pipes going into the top of it, the leak is coming from the driver's-side fitting. I can see it bubbling up where the metal pipe comes out of the switch canister.
I tried tightening the bolts that seem to hold the two lines in place, that did nothing. How do I fix this? Would it be the switch that's leaking, or an o-ring on the metal pipe? It looks as though the bolt next to the line holds it in place, I don't know if the little arm that presumably would run from the bolt to the fitting for the pipe got weakened/bent, could that be causing this? I haven't tried to take anything apart yet, so I'm not sure how this goes together, my apologies if I'm misinterpreting how it goes together.
Thank you for your help!!
BkGreen97
Apr 2, 2016 05:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
