Changed knock and o2 sensor & still hesitation
Old Jul 7, 2004 | 07:33 AM
sagemistse's Avatar
So my CEL came on 2 months ago due to a bad O2 sensor. The knock sensor code came back as well. I replaced both and reset the CEL and it has not been back on again. Before the change I was experiencing alittle hesitation in the higher gears. After the o2 and knock sensor were replaced I thought it had gone away. but while driving yesterday i noticed the same hesitation. not as bad but it was still there. Any Ideas as to what this can be?
Old Jul 7, 2004 | 09:03 AM
njmodi's Avatar
Do I get a tax break?
Is it only at high speed? Maybe a clogged fuel filter...
Old Jul 7, 2004 | 09:06 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
u sure ur knock sensor was bad? when you o2 sensor kicks in, it will also trigger your knock sensor. anyway, check your ignition coils.
Old Jul 7, 2004 | 10:33 AM
flashover's Avatar
Yep check coils, also. Try putting the ecu through its relearn cycle.
1) Warm engine to operating temp.
2) Disconnect battery until the clock resets.
3) Start car. DO NOT TOUCH ANYTHING ELECTRONIC. Let the car run for 5 minutes.
4) Turn car off, then take out the key. And your done.
Pretty much, from what i understand, the ecu records data all the time, to create an average.
This is setting your baseline idle to ideal conditions, with no loads, radio, windows going up and down, etc.
I know it works, or at least helps.
Good luck
Old Jul 7, 2004 | 11:12 AM
ogparjay's Avatar
fuel filter, did you change all three of the 02 sensors? just want to know for reference.
Old Jul 7, 2004 | 01:06 PM
sagemistse's Avatar
only the front right one thats the only code that came back other than the knock sensor.
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
