300zx mafs on a 96 max??
Old Jul 9, 2004 | 03:23 AM
vq30max's Avatar
i got a 96 maxima and i hooked up my 300zx maf sensor today and i am bogging out at about 3,000 rpm- 4,000 rpm.....my mods is intake, gutted cat converter, unorthodox udp, iat resistor, nitrous but didnt run it yet.....anyone got any clue why my car is dong that??? is it too rich??? do i need to tune it?? ?do i need to get a ecu???? let me know......all your help is greatly appreciated....thanks, russell
Old Jul 9, 2004 | 04:00 AM
Stephen Max's Avatar
The Z32 maf is calibrated totally different from the A32 maf. It can meter substantially more air than the A32 maf, yet the output voltage range is the same 5.1 V. So, for a given amount of air going into the engine, the Z32 maf is giving a much smaller signal to the ecu. The A32 may have enough latitude to compensate in closed loop operation based on what the O2 sensors are telling it, but anytime during open loop operation (acceleration) you are going to be very lean, hence the bogging. Take it off ASAP and put your oem maf back on.
Old Jul 9, 2004 | 04:13 AM
ABK's Avatar
ABK
you need to run JWT ECU programed for the given maf. If you wonna run a bigger maf you might as well get a cobra one. also what the .... iat resistor.
Old Jul 9, 2004 | 04:21 AM
By the way, the oem maf is good for 350 hp at the flywheel, so there is no use for a larger one unless you're boosted or juiced, and then you have to have the ecu reprogrammed, like ABK says.
Old Jul 9, 2004 | 04:32 AM
Pimpmobile's Avatar
people who use z32 MAF are running high boost so they need that broader spectrum of air flow measuring. If you aern't FI take it off.
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
jds22
Sep 29, 2015 02:03 PM
