e-brake not working
Old Jul 21, 2004 | 02:47 PM
Slaytan69's Avatar
e-brake not working
I'm having a problem with the E-brake. Whenever I pull it, I don't stop...I keep rolling at the same speed. Is there any way to tighten it?
Old Jul 21, 2004 | 05:12 PM
Ant96GLE's Avatar
CHeck your E brake cables and make sure they havent been crushed which happens quite often when you jack up the car.
If not simply inspect the cables from the caliper all the way to the front. Check the e brake itself under the console and make sure its still connected as well. If not inspect your rear calipers...
Old Jul 21, 2004 | 10:33 PM
Max Mutes's Avatar
My one cable to the driver side is frozen. I can't pull my e-brake, and if I do pull it then my rear wheels lock up. Any suggestions on how I would go about this to fix on my own?
Old Jul 22, 2004 | 02:07 PM
Ant96GLE's Avatar
Theres 3 cables, one to each wheel which connect to under the handbrake and another that goes directly to the hand brake... I changed my drivers side one because it was crushed. Its pretty simple, it hooks on both sides. A new one from the dealer is about $65.. thats how much I got mine for.
Old Jul 22, 2004 | 02:55 PM
njmodi's Avatar
Do I get a tax break?
to what ^^^ said... the cable itself is a piece of cake to replace - the toughest part for me was getting all the exhaust heat shields off with all the bolts frozen/rusted... damn midwest winters and road salt!
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
