Rattling noise from engine.
Old Jul 21, 2004 | 05:39 PM
maxdis1's Avatar
Ok , quite simply: whenever my AC is on there is a rattling noise from the engine. It sounds like a chain without oil, grinding. If I run the RPMs in 2nd gear to about 3k Rpm the noise becomes more pronounced. I am temporarily solving the problem by running a very low RPM and little AC whenever possible. I have and am currently using 91 octane gas . The car is due for new spark plugs at 68k miles( ok so I am over a bit , lol) and new knock sensor, scheduled for this weekend.
Your input will keep me away from the "stealer"! . I will be looking foward to solve this annoying problem with your help.
Thanks to everyone who reads this and for those in advance who have the answer to the problem.
Old Jul 21, 2004 | 05:51 PM
ABK's Avatar
ABK
does it only do it when AC is on, then it's possible that you AC compressor might be loose (the bolts that hold it believe there are 3 or 4 of them). Also you AC electric clutch on compressor might be messed up. Also you idler pulley might be messed up. I would check for play in all of them, start the engine up and take a look at them (don't touch). Also you might have ratling heatshield. You could have a ratling timing chain tensioner uncommon on 97s. The worst case scenerio you got a spun rod bearing or piston slap but I never heard of this happening to VQ, did you run on low oil lately?
If nothing check out of the above test for spun rod bearing, or piston slap by unplugging coil packs from each cylinder, if the noise goes away then you are in some serios trouble.
Old Jul 22, 2004 | 10:01 PM
maxdis1's Avatar
Thank you very much with your detailed input. Apparently the compressor is secured, both heat sheild are intact , so I am hoping that it is not the others that you have mentioned. I pray that this is not as bad as it may be........
Thank you again for your reply . I now have confidence that elimination should lead to a solution.
Old Jul 22, 2004 | 10:17 PM
Who's Avatar
Who
It's most likely the belt tensioner pulley bearing...I changed the bearing on both our cars after getting the same kind of noise. Try to shake the pulley while it is on the car...if it shakes then the bearing is bad...should be pretty cheap.
Old Jul 22, 2004 | 10:41 PM
voltman's Avatar
Sounds like me.
Old Jul 23, 2004 | 05:00 AM
maxdis1's Avatar
Thanks Guys .
Old Apr 21, 2009 | 09:07 PM
nizmoRUS's Avatar
hey guys, 3 days ago i recorded my car doing a crazy rattling noise on video. hours later it went away has been back since. if you dont mind please watch the video and listen to the sound and tell me if it is the rattle noise that is typically related to timing tensioner/chain.
http://video.google.com/videoplay?do...20982898103745
thanks
Old Apr 22, 2009 | 07:20 AM
pmohr's Avatar
No more Maximas...
thanks
Why did you bump a 5 year old thread for this?
If you rev it up, does the noise stay constant, rise with RPM, go quiet for a second while it drops back to idle?
Old Apr 22, 2009 | 04:47 PM
nizmoRUS's Avatar
I didn't start a new thread to try to save the .org guys some storage space.
I didn't try to rev up at the time because it sounded like some belt will come flying out of engine area if I put any more pressure and now the sound is gone and (I guess) fortunately I can't replicate it.
Old Apr 22, 2009 | 04:51 PM
pmohr's Avatar
No more Maximas...
...which is why the newbie thread is there.
So it's no longer rattling at all?
Old Apr 22, 2009 | 05:24 PM
nizmoRUS's Avatar
I see. Thanks for the tip. No longer rattling but sure has scared the living crap when it did. I was also low on oil which could have been the reason. I will watch it closely from now on and see if the sound returns. Car has 160K plus so it eats and slowly leaks oil.
Old Apr 22, 2009 | 08:02 PM
larso1's Avatar
Man, that almost sounds like an exhaust leak from the exhaust manifold or in the downpipe? Maybe a bad fuel injector? I personally wouldn't characterize it as a rattle...more like a pressure leak from a cylinder, head gasket, or missing/broken spark plug?
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
