Quickest And Easiest Way To Installing Clear Corners?
I recently just bought my 98 max SE first mod was debadge now im on to my second mod which is basic but i wanted to ask if any one knew the easiest and quickest way to install the clear corners cause I just came down with mono and i dont really wanna struggle to much installing them since the doctor said i shouldnt even leave the house but screw him cause ups just came with my clear corners and i want them in. Any one with the easiest and quickest way way please drop me a line.
Welcome to the ORG!
I assume you're talking about the bumper lights? If so, just take a flathead screwdriver and wedge it between the two lights and pop the flatter light out, using the other light for leverage. Then, using a phillips screwdriver, unscrew the one screw that's keeping the other light in. Twist the harness to remove it from the housing.
~THT
~THT
when u put clear corner in, do u need a different lightbulb? will it look good with stock bulb?
________
PetiteBella live
________
PetiteBella live
Originally Posted by Roscoe139
Mind if I ask where you got the corners? I ordered as set from Custom Enterprise back on July 6th but they say they are out of stock. Getting impatient!
Tools needed: Metric wrench set (10mm), phillips & flat head screwdriver, 2 thin washers approx. 5/8" diameter with a hole 5/16" in the center, cloth
1. Start by removing the stock (smaller one) orange corner blinker piece. Place a piece of cloth in between the small orange and large orange cornering lights. Put the flat head screw driver inbetween and slowly pry the piece, away from the body.. It's only connected by a little ball n socket device, so it'll just pop out.
2. Once you get that out, remove the bulb by twisting CCW, and replace with clear lense, don't put it back yet..
3. For the larger orange turn signal, use the phillips screwdriver to remove that single screw and then the whole piece will pop out. Remove the bulb and replace with the new clear corner piece. Put it back in, and secure with that screw.
4. You'll notice, that if you try pushing the remaining piece backinto that old ball n socket hook, the lense will tend to pop out again. That's why you want to lock it in place. Remove the metal "ball" part of the clear lense and remove the pastic "socket" part that's on the car. You want to put the washer, on the inside of the car, and tighten the screw to the lense from the inside.
5. From underneath the fender of the car, remove the 2 screws keeping the black fender wall attached to the car frame.Pry open enough space, to get your hand in there, along with a 8mm socket wrench.
6. Once you got your hand up there, take a rest and say wow! what the heck is my arm doing up there.
7. OK. now that you've done that, tighten the "ball" metal screw to the lense with the washer inbetween it. It goes SCREW->WASHER->CAR->LENSE. Tighten it a few turns, then you're set. Take your arm out, and close up the fender wall. Repeat other side.
credit: cheston
credit: cheston
is the "screw-washer-car-lens" talking about the smaller, flat piece? i'm not understanding where this "ball" metal screw is at and how to "tighten the screw from the lens from the inside" please clarify. thanks.
once and again guys thanx
k guys thanx alot with the instruction and yes it was crazy easy just thought i would ask my fellow org people just to make sure i hate breaking stuff then taking the time to figure out how to fix it specially when im sick by the way i spit up 5 peice on my tonsules today and i still made it out to the max to change the lens yay me ::breaths on nails and wipes them on shirt::
once and again guys thanxThread
MaxLife17
Jun 27, 2019 01:37 PM
ballerchris510
Sep 10, 2015 09:35 PM
lowpost99
Sep 8, 2015 05:06 AM
JoshG
Sep 5, 2015 10:10 PM
