changing radiator fluid
Old Jul 22, 2004 | 02:17 PM
DoGGx23's Avatar
How do you take out the plastic plug underneath the radiator? I have a 99 maxima SE. I do not want to mess up that plastic bolt what is the best wat to remove it?
Old Jul 22, 2004 | 02:42 PM
SkinnyMax's Avatar
maxima no more
just pull off the lower radiator hose to drain it
Old Jul 22, 2004 | 02:54 PM
njmodi's Avatar
Do I get a tax break?
The plug can just be unscrewed with a philips head screwdriver... no big deal.. should not be on that tight...
Old Jul 22, 2004 | 04:33 PM
Ant96GLE's Avatar
You have to take off some of the plastic shields under there to get it out... your better off just unscrewing the lower hose, its easier and has the same effect
Old Jul 22, 2004 | 05:26 PM
DoGGx23's Avatar
Are there any step by step instructions on flushing out a cooling system for a 99 Maxima SE? How do I remove the bottom hose? Are there clamps holding it down or do I just pull it off? How many gallons will I need to refill my whole cooling system back? Any tips will be helpful... Thank you!
Old Jul 22, 2004 | 05:28 PM
njmodi's Avatar
I don't think you have to take anything off to get to the bolt... I didn't. Here is a link that shows you pretty much everything you need to know to do this yourself:
http://www.motorvate.ca/mvp.php/502
From his pics, the radiator drain is accessible from below.
Old Jul 22, 2004 | 06:01 PM
ogparjay's Avatar
use a garden hose
Old Jul 22, 2004 | 07:37 PM
98SterlingMax's Avatar
Humble '06 TL Owner
I just did a coolant change last weekend and whenever I do it on a car with a plastic plug like ours, I always replace the plug with a new one. Well, this was the first time I tried to reuse the old one (the dealer was closed) and when I replaced and tightened the plug it broke. I did end up getting it back out though. Moral of the story: ALWAYS buy a new plug with the washer, it seems that the heat makes the plastic somewhat brittle after time.
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
pktaske
Sep 4, 2015 08:40 AM
