Can Someone Post A How To On......
Old Jul 24, 2004 | 01:53 PM
Negativezero's Avatar
Can Someone post a "how to" on how to fix power seats? preferably the front paasenger power seat? Is it difficult, where can i find the parts needed?
Only one side of my seat works, other side won't move.
Please help.
Old Jul 24, 2004 | 03:00 PM
njmodi's Avatar
Do I get a tax break?
Do you hear anything when you try to move the seat, look under your seat and make sure all the connectors are secure. Also check the track that the seat slides on to make sure your missing fortune hasn't jammed the seat on the track.
Its not a howto - but it should give you some starting points.
Old Jul 24, 2004 | 11:03 PM
tdaily's Avatar
The way the seat is set up is that there's a motor on one side, and a cable running to the other side. Obviously, the cable has broken, or come unhooked. If you haven't taken the bolts out of the seat and lifted it up to look underneath, you should do that. Once you see the cables to which I'm reffering you'll recognize them. Also, you should be able to tell if it's broken or simply unhooked. The bad news is that I pretty sure you can't buy new cables, so if it's broken you may have to try and find a junkyard to sell you one. Also, don't forget to check the rail for foreign objects: I've actually seen a quater get stuck in one rail and prevent that side of the seat from going forward.
Old Jul 25, 2004 | 01:46 AM
maxima_kid's Avatar
I got that problem. Fixed it with new leather ones.
Old Jul 25, 2004 | 07:16 PM
Any other Suggestions?
Bumping to see if anyone else has suggestions. Thanks to the above repliers.
Old Jul 26, 2004 | 09:05 AM
cam_honestiam's Avatar
These answers are probably as good as it gets. The only things that would prevent your seat from moving are:
-Bad Motor / No electrical connection
-Jam in the track
-Disconnected / broken drive cable
Check these and fix whichever describes your situation.
Old Jul 29, 2004 | 06:01 PM
-Jam in the track
Motor work cuz right side of passenger seat moves.
Checked tracks, they were clear
and the cable was connected
anybody think of anything else. IS THERE ANYWHERE I CAN GET A NEW CABLE??
Old Jul 30, 2004 | 09:08 AM
[CENTER] anyone?
[CENTER]
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
09maxshawn11
Sep 30, 2015 10:28 AM
