Damn Codes!
Old Jul 25, 2004 | 02:05 PM
maximka's Avatar
Damn Codes!
I got 2 codes today 03-04 and 11-03
i know that 03-04 means i need to get a new knock sensor, even though i don't know why it went bad? i used the 93 oct. gas...
but 11-03 (Improper Shifting to First Gear (A/T)) ????
did anyone have the same problem? how do i fix this?
Please help!!!
Serge
btw: where can i get the cheapest knock sensor? except ebay...
Old Jul 25, 2004 | 02:10 PM
Kevlo911's Avatar
Kevlo for President
1103 1104 1105 1106
Since DTCs 1103 to 1106 deal with the transmission, there is info on the 1106 DTC. Everywhere you see "4th gear", simply substitute "1st gear".
Diagnostic Trouble Code 1106 means "Automatic Transmission 4th gear malfunction."
This malfunction is detected when the automatic transmission does not shift into fourth gear or the torque converter clutch does not lock up as instructed by the Transmission Control Unit. The factory service manual lists these possible
causes...
- Shift solenoid A
- Shift solenoid B
- Overrun clutch solenoid valve
- Line pressure solenoid valve
- Each clutch
- Hydraulic control circuit
- Torque converter clutch solenoid valve
You can do some troubleshooting without opening the automatic transmission. Find the harnesses which emanate from the transaxle. One of them terminates in a brown plastic connector with eight pins. This is connector F42, located (approximately) above the transaxle case and below the black plastic engine air intake ductwork. With the engine off, disconnect F42. You want to measure the transmission side of F42. Hold the connector such that the plastic latch is at the top. You should now see two rows of four terminals. These are numbered (top row, left to right) 1 - 4, and (bottom row, left to right) 5 - 8. Make resistance measurements between a clean ground and the following terminals:
#1, Shift solenoid B, 20 - 40 ohms.
#2, Shift solenoid A, 20 - 40 ohms.
#3, Overrun clutch solenoid valve, 20 - 40 ohms.
#4, Line pressure solenoid valve, 2.5 - 5 ohms.
#5, Torque converter clutch solenoid valve, 10 - 20 ohms.
There is also a "bench test" procedure for testing these solenoids with a 12 volt supply such as a car battery. However, this requires removal of the shift solenoid valve assembly. I don't know if you want to get involved with that.
GD on Knock Sensors, check the Group Deals forum.
Old Jul 25, 2004 | 02:19 PM
maximka's Avatar
Holy S**t!
i am not good at things like that... damn it!
what will happen if i ll keep driving this way?
Thanks Kevlo911!
Old Jul 25, 2004 | 02:40 PM
Kevlo911's Avatar
Kevlo for President
Reset hte ECU and see if the codes come back.
Old Jul 25, 2004 | 05:49 PM
maximka's Avatar
still have them
sigh
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
