what could be the reason of a *sometimes* long crank to start the car?
Jul 26, 2004 | 11:40 PM
over the past several weeks i noticed that sometimes my car would take a long time of cranking before it starts. today for instance, when i was leaving work, it took a good 1.5 to 2 seconds to start. usually it takes about .5 or so sec. to start. today was the longest i had to hold it to start it. is my starter dying? fuel pump? what could it be?
Jul 26, 2004 | 11:53 PM
weak battery, bad starter?
Jul 27, 2004 | 12:16 AM
the battery was purchased brand new about 2 months ago. i'm thinking it might be the starter but not sure. so i wanted to see if others here had the same problem.
Jul 27, 2004 | 05:03 AM
If its turning over, then the starter is working. Assuming TB was cleaned, air/fuel filters changed, I would research crank and cam position sensors, especially if you get hard starting as well.
Jul 27, 2004 | 07:47 AM
if your running close to empty in your tank, that would be a reason.
Jul 27, 2004 | 08:08 AM
well i have tghe same problem and i also have the evap cannister code.
could this be the reason why it is hard to start?
Jul 27, 2004 | 09:35 AM
i have noticed that mine takes awhile to start when my tank is less than 1/8th full. see if thats your problem. I have major evap problems also. my charcoal canister is currently off my car
Jul 27, 2004 | 09:53 AM
I would do a fuel filter change and see if that clears it up. Otherwise, I second the camshaft position sensor. I've just noticed a lot of people have troubles with that.
Jul 27, 2004 | 09:55 AM
check oil level
