PIAA Headlight question
Old Jul 27, 2004 | 01:13 PM
fadeaway's Avatar
Go Hokies!!
Hey everyone,
Please take a look at this auction:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7912315362
PIAA 9004 Xtreme White Plus
Is this a solid choice for headlight replacement from stock? Also, anyone know the difference between 9004, 9005, 9006, 9007? Brighter light as you go up?
Also, these lights won't be extremely bright blue, will they? Will they seem ricey on the road?
Thanks,
Dan
Old Jul 27, 2004 | 01:19 PM
JeEvE's Avatar
Stock is 9004, Im not really sure wat the differences in brightness between the others are. The Xtreme Whites are whiter then stock and if you look straight at them you can see some blue. They are white on the road and you cannot see any blue so it will not look ricey. Also, look around on ebay more becuase you can find them cheaper then $60.
Old Jul 27, 2004 | 01:35 PM
fadeaway's Avatar
Go Hokies!!
Thanks for the info. Anyone know the difference between thre different 900x models?
Thanks,
Dan
Old Jul 27, 2004 | 03:31 PM
tomservo291's Avatar
I got the PIAA 9004's Xtreme White Pluses last week, very pleased. Very difficult to see the slight hint of blue, you have to try really hard.
Old Jul 27, 2004 | 04:23 PM
fadeaway's Avatar
Go Hokies!!
Thanks.. also.. these lights are legal in the 50 states, right? Just makin sure..
Thanks.
Old Jul 27, 2004 | 07:15 PM
bluman3's Avatar
Thanks,
Dan
the difference between the 900x is the connector on the back of the light. it just so happens ours is the 9004 and for example the 9007 is for a ford explorer. different car makers use different lamps.
Old Jul 27, 2004 | 07:31 PM
Rick James's Avatar
Thanks,
Dan
9004 and 9007 are dual filament bulbs ( high and low in one bulb)
9006 and 9007 are for a two headlight system (9006 low, 9005 high)
thats for the 9xxx series there are others.
Old Jul 28, 2004 | 07:17 AM
danbortz's Avatar
im running PIAA extreme white bulbs throughout my front end (headlights, corners, side markers, fogs)
fogs are amazing, the headlights have a slight slight hint of blue only in the dead center of the beam where the bulb itself is...
i definitely recommend them!
Old Jul 28, 2004 | 07:25 AM
andy21's Avatar
yea i got them too. i like them but if i were to buy again I would get Nokyas because I wanted a little more blue and because they are cheaper. However I would still reccomend them if you want just pure white coloring.
Old Jul 28, 2004 | 07:40 AM
I don't think that it's any actual blue light that they give out. When you look at them dead center it still doesnt appear like a blue light emitting, but you can see blue inside the reflective housing. I think it's just a reflection of the blue tip of the bulb on the chrome; just my .02c
Old Jul 28, 2004 | 07:59 AM
image's Avatar
DOnt mean to ***** up the thread.. but if i wanted to buy the fogs and corner lights i'd still get the 9004 regardless????
Old Jul 28, 2004 | 08:20 AM
9004 is the bulb type for the headlights (dual filament hi/low beams.)
if you look in your owners manual in chapter 7 there is a chart with all the bulb types, wattages and how to replace them.
the fog lights are H3 55w, (by corner I assume you mean "clearance lights" which reside next to the headlights) are 1157's, the front turn signal is an 1156 and the sidemarker next to the turn signal is a 194
Old Jul 28, 2004 | 05:18 PM
image's Avatar
awesome thanks!
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
