Question after Budget ypipe install
Old Aug 2, 2004 | 09:15 PM
99maxk2's Avatar
After grueling hours of getting rust in my eyes and ripping out the stock y pipe, I finally got my buget y pipe on. I cranked my car and heard an exhaust leak and after tightening some bolts, the noise lessened, but is still there. I was told to give it about a weak for the y pipe to heat up and somewhat reform itself and tighten the bolts again to get rid of the leak. Has anyone else had a problem with a y pipe leaking after install?
Old Aug 3, 2004 | 12:00 AM
BadKarma99-4spd's Avatar
no leaking here. did you lightly tap the rings into place before lifting the pipe into position?
are you sure its a leak?
Old Aug 3, 2004 | 07:01 AM
99maxk2's Avatar
no i didnt, oops lol. And yea cause theres not enough back pressure comin out of the tailpipe and i hear and feel the exhaust comin out.
Old Aug 3, 2004 | 07:20 AM
Taken2DaMax's Avatar
Looks like you're going to have to put it up on the rack again. And check those gaskets.
Old Aug 3, 2004 | 07:27 AM
99maxk2's Avatar
sounds like a this weekend project to me
Old Aug 3, 2004 | 07:31 AM
deezo's Avatar
You're probably getting a leak because you didn't clean the surface of the flange on the cat. It helps if you grind it to a smooth surface.
Old Aug 3, 2004 | 08:09 AM
99maxk2's Avatar
Its not from the cat, its from the section thats is vertical. Ima try to let the y pipe form to itself and if that doesnt work i will re-install it and tap in those gaskets.
Old Aug 3, 2004 | 01:37 PM
Brudaddy's Avatar
Also, are you sure that you are just not used to the already raspy sound of what the y-pipe makes? I mean, it is a good bit more raspy than the stock pipe anyway. That could be your problem....not really a problem at all.....you are just not used to it.
Old Aug 3, 2004 | 07:07 PM
99maxk2's Avatar
It is definately is raspy, but i still believe i have a leak. My friend is gettin me into his shop tomorrow so ima see if i can do anything to fix it. How raspy is it and where does the sound come from? I hear the sound from the y pipe itself, is this normal?
Old Aug 4, 2004 | 06:32 AM
99maxk2's Avatar
anyone know?
PH98I30
Jan 9, 2025 08:08 AM
vingodine
45
May 21, 2016 12:46 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
