O/D or Transmission Problem?? HELP
Old Apr 4, 2001 | 05:24 PM
Daddy Fat Sacks's Avatar
Today, when I started my car, my OD button started flashing on the dashboard. It flashed a few times then went away. And it does it every time I start my car now. What can this be.
Old Apr 4, 2001 | 05:31 PM
Daniel B. Martin's Avatar
Fail-safe
A quote from the '99 Maxima Owner's Manual...
Fail-safe
When the fail-safe operation occurs, the next time the key is turned to the ON position, the O/D OFF light will blink for approximately 8 seconds after coming on for 2 seconds. While the vehicle can be driven under these circumstances please note that the gears in the automatic transmission will be locked in third gear.
If the vehicle is driven under extreme conditions, such as excessive wheel spinning and subsequent hard braking the fail-safe may be activated. This will occur even if all electrical circuits are functioning properly. In this case, turn the ignition key OFF and wait for 3 seconds. Then turn the key back on the the ON position. The vehicle should return to its normal operating conditions. If it does not return to its normal operating condition, have your Nissan dealer check the transmission and repair if necessary.
Old Apr 4, 2001 | 05:41 PM
Thanks Danny. Does that mean that if I put it in the on position and turn the car back on, if the light doesn't blink, there is no problem?
Old Apr 4, 2001 | 06:07 PM
Re: Thanks
Yes.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
bryants95max
Oct 2, 2015 12:52 PM
The Wizard
24
Oct 1, 2015 08:47 PM
dcardello
Sep 3, 2015 11:44 PM
