Need info about the rear brake piston.
Old Aug 5, 2004 | 12:16 AM
Noslen's Avatar
How do i get the rear brake piston to retract? someone told me to screw them in, but they're pretty damn stiff. and if i need to screw them in, do i turn it clockwise or counter clockwise.
one last question, do i need to sand down my new rotors?
Old Aug 5, 2004 | 12:17 AM
Prophecy1's Avatar
If you read the stickies you would know. A special tool is required. Or read an Hayes or Chiltons.
Proph
Old Aug 5, 2004 | 12:19 AM
Prophecy1's Avatar
8 Dollars to resurface your rotars at O' Rielly's Auto parts . Rotars are sensetive you may just have to buy new ones and they are not that expensive.
Proph
Noslen's Avatar
Proph
i tried, there's no rear brake disassembly/assembly how to! that is why i'm asking
I also read through the Hayes, 93 thru 2001, there's nothing about 98 rear plate rotors, all they have info on is the ol' school brake drums.
I have new rotors, all 4
Guttermouf5150's Avatar
you dont really need to sand them, but you should clean off the anti-corrosion film they put on at the factory. use some dish soap and water. sanding wont hurt, it's just not really necessary.
Old Aug 5, 2004 | 12:51 AM
Noslen's Avatar
ok, ok, i've done some research, and found out that i have to turn the piston. but which way? clockwise or counterclockwise?
Old Aug 5, 2004 | 01:01 AM
98SterlingMax's Avatar
Humble '06 TL Owner
Clockwise, the special tool helps but pliers will work. Just use the tips of the pliers into the grooves on the piston.
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
