my max failed inspection-help
I brought her in yesterday and the comp brought up 3 codes that i need to fix, P0100 (0102), P0325 (0304), and P0153 (0414). I found out that they mean my mass air flow sensor, knock sensor, and the last one was undefined. Does anyone know what I can do to fix these on my own???
Maf
Could be a couple of things causing it, but best bet is to take out the MAF and clean the filament with alcohol, then hook it back up and make sure all the plugs are nice and tight... Not sure about the KS... Didn't know that would affect an emissions check...
Good luck
Keir
Good luck
Keir
The 0304 code is usually a ghost code that comes up with another code as is most likely NOT the problem. My guess is your knock sensor is fine but the other code is an 02 sensor that is bad. Also clean the filament on your maf
It is right under the intake plenum, in the middle and on top of the engine. If you look under the intake plenum from the driver's side you will see a black plastic part that has a wire going to it. This is the KS. It is supposed to detect engine knocking and retard the timing to avoid damage to the engine.
My car failed the inspection too, not because of emissions, but because my computer keeps saying that some monitors are not ready (the limit is 2 and 3 of them say NOT READY). I have no codes at all. Will tacke this issue next week.
Good luck with your next inspection.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
