VQ30DE high performance engine rebuild kit questions....
looking around the intro-net for some an introduction to some max parts, and i came across the following:
http://<a href="http://www.importper...issan.html</a>
located at bottom of page.
the kit contains several different choices, but what caught my eye was the option for 93 or 94 mm bore, and the compression ratio option (seeing as that 10.5 - 1 would be great)
maybe one of you knowlegeable gear heads would know what the stock engine setup for bore size and piston compression ratios would be.
also, what would a good high performance cam? I havent seen and/or found one yet, and they might not exist.
thanks in advance for your help.
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
