Changed Knock Sensor, still pulling codes.
Old Aug 5, 2004 | 02:26 PM
Conrad283's Avatar
I need a truck
I knew my knock sensor was dead or "partially working". I knew it was, so I changed it. When I pulled out the old one it was cracked in 3 spots. But even after I switched it out I'm still pulling the code.
I also pulled 1205 which is Line Pressure Solenoid Valve. Are the two related?
Old Aug 5, 2004 | 02:42 PM
MaxxAddict's Avatar
forget the pulling of codes, how does the car PULL? I've heard that u get ur low end back.
Old Aug 5, 2004 | 02:44 PM
BradsMaxima's Avatar
I heard from a few places mostly dealerships that the knocksensor code comes with another one so try get that other code cleaned up, and make sure you reset your ecu, if you didnt reset your ecu after you replaced the sensor then it will still be there.
Old Aug 5, 2004 | 02:45 PM
Conrad283's Avatar
I need a truck
It felt better, but I only took it around the block, but I drove it pretty hard.
It felt better in that from a start when I would run out first gear there would be a big jerk when the RPM's would drop. Now it's "smoother."
Old Aug 5, 2004 | 02:46 PM
Conrad283's Avatar
I need a truck
Yes, I reset my ECU. But it came back 2 starts later.
Old Aug 5, 2004 | 03:11 PM
When I tried to tell the dealership about my KS codes they said BS, thats not the problem.. its something else... It always comes up with a second code. So I dunno Im like okay bud I got a knock sensor in my hand and its got three cracks in it. so hes like nope.. its got something to do with the other code ( I was also getting a Neutral switch code) so I took care fo the KS reset the ecu and I was okay for a few days.. and then the Neutral switch code came back.. so I got to get that look at tomorrow.
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Slamrod
Sep 3, 2015 07:38 PM
maximusrising
Sep 2, 2015 09:55 AM
maxinout93
Aug 20, 2015 02:17 AM
