Starting problems
Starting problems
Hey all, got a prob. my max (98 gle) has 105k miles, never a problem. last weekend, tried to start it, nothing happened. took battery to test(battery and alternater tested fine), put back in, and she started, but took a couple seconds(slow crank). started slow all week . then this morning same thing, tried to start, and nothing happens(lights, radio still work) . got a ride to work(I was late), got home, and it started right away. 5 minutes later, tried to start, and nothing happened again. Could it be the starter? sorry, i've been reading the forums all week, but found nothing similar.. Thanks in advance
same thing happened to me.. i got the battery and the starter checked... they both came out good. i put everthing back in the car and it ran well for a week (other than when i started it i had to give it a little gas) just last night the max just wouldn't start and the starter is rotating really slowly. sometimes doesn't rotate at all. good luck!
well... is it possible that the starter will operate normally during a bench test but crap out once on the car? i only say this because the starter tested out just fine last week. thx for any input.
smokeyone- not trying to jack your thread... it's just that we have similar problems.
Ok, problem is back. Drove to work and back thursday, slow starts, then thursday night wouldn't start again. kept trying all night periodically, got it going about 2am. worked all day friday, till i got home, car sat for a few hours, and now wont start again! Help badly needed! thanks in advance.
I have a brand new battery, alternator seems fine...and brand new starter...and I had trouble staring my car, it started up really slow and almost wanted to die out ofter it started from a cold start, also giving it gas helped...cleaned my TB, and replaced my engine coolant temp sensor...and all my problems went away...
I'll also be replacing my ignition switch today. I also have trouble starting. Ill tell you guys how it goes.
EDIT: Well I just replaced the ignition switch with a new one. Put everything back and tried starting it. It started up on the first turn of the key. Before I would have to crank through the first try, sometimes through the second, and then my car would start and then hesitate a little. Now it fires right up without any hesitation. It took about 10 min to replace.
For anyone having starting issues, by all means look into the ignition switch. It gets overlooked big time. I thought my starter was going to take a crap, but I thought wrong.
Some symptoms I had:
Long cranking when cold
Had to turn key past "on" for it to crank
when started, car would idle at 800 rpm, instead of going to 1500 like it should.
Pic of the switch:
$38 at Carquest, it might be cheaper elsewhere. Hope this helped..!
Pic of the switch:
I'm sure its my starter going, started it 4 times yesterday by tapping on starter with pair of pliers, since then started about 7 times normally, no problem. Im going to regrease starter first, see if that helps. Ill probably change ignition switch soon too.
sctludwig
Sep 1, 2022 01:32 PM
trungg86
Sep 4, 2015 04:58 AM
