Bose Sound system questions???
Old Aug 5, 2004 | 09:59 PM
fusionx21's Avatar
I wanted to know if it is possible to add a sub, with out redoing all the speackers and head unit if you already have the bose system.
Old Aug 5, 2004 | 10:03 PM
f550maranello2's Avatar
hell yea its simple man
Old Aug 5, 2004 | 10:15 PM
fusionx21's Avatar
how would you do it then
Old Aug 5, 2004 | 10:23 PM
nostrixoxide's Avatar
install a line convertor @ the rear speakers.
Hook up your amp.
Wire up your sub.
Vibrate your windows..
It's really that easy!!!!
Old Aug 5, 2004 | 10:55 PM
dko683's Avatar
just like nostrixoxide said, install your amp to the rear speakers since the bose head unit doesn't have a sub out. i forgot which wattage you need for the converter tho. i went to circuity city/best buy and they only carried weaker ones.
Old Aug 6, 2004 | 02:44 AM
Prophecy1's Avatar
You should read the forums and ask certain questions in certain forums. THere are stickies and FAQs for things like this, which would help you alot quicker and give you illustrations.
The guys above are correct.
PRoph
Old Aug 6, 2004 | 06:48 AM
man u dont need no converter just run singnal wires from each of the speakers into your amp(providing your amp has high level inputs) then run a power wire throgh you fire wall i suggest at the point right above your brake pedal (where the clutch is posed to be in a manual) i did this all in like 2 hours.
JRod28
Dec 29, 2023 09:56 PM
6spd4dsc
May 9, 2022 12:30 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Abdelrhman
Aug 17, 2015 12:16 PM
