Tokico Illumina settings...
Old Aug 18, 2004 | 05:10 PM
_ck69_'s Avatar
I've had the Illuminas for about a couple weeks now. I've settled on a 2/F and 3/R setting for my car. For all the Illumina owners, what are your settings at?
Old Aug 18, 2004 | 05:40 PM
macallik's Avatar
3 front / 4 rear
Old Aug 18, 2004 | 05:44 PM
vsamoylov
so do they feel when they are at the point ofr the maximum performance? is bodyroll noticable?
Old Aug 18, 2004 | 06:08 PM
macallik's Avatar
body roll is reduced greatly and you feel every bump on the road (all the ones you never knew was there). i like it stiff better but some like a more comfortable ride so if that you, go 2f,/2r
Old Aug 18, 2004 | 06:11 PM
vsamoylov
no when i get these i want the best handling possible from them. i am on H&R right now but thinking of getting Tein.
Old Aug 18, 2004 | 06:29 PM
VQuick's Avatar
Chassis Freak
2 front / 3 rear
Together with Tein High Techs this is pretty comfy! Not much rougher than stock SE, but significantly better handling.
Old Aug 18, 2004 | 06:44 PM
_ck69_'s Avatar
Originally Posted by VQuick
2 front / 3 rear
I don't think "comfy" is the right word... I do feel a huge difference in ride quality IMO. Even at the stiffest setting, I still seem to get some body roll. I'm not completely satisfied. I've heard that adding a RSB to a lowered car won't make a 'huge' difference. Is this true?
Old Aug 18, 2004 | 06:56 PM
gtr_rider's Avatar
192.168.1.1
Originally Posted by macallik
3 front / 4 rear
Thats the best for me
Old Aug 18, 2004 | 06:59 PM
Big_Ham's Avatar
MaximaFreak
2 front / 3 rear
I had 3/3, but I was bottoming out on some roads in Tampa and needed the stiffness to keep from bottoming them out.
Shortened struts are the best way to combat that ... not Illuminas.
Overall tho ... very happy with them.
Old Aug 19, 2004 | 07:00 AM
Larry H's Avatar
Originally Posted by Big_Ham
2 front / 3 rear
2 front 3 rear here too, with progress springs. good for slightly spirited driving but for anything more than that body roll is still apparent. with 3/3, the ride gets worse and the handling doesn't get much better. I'd like to try 3/4 but I hate removing my amp to get the rear settings.
overall it doesn't ride or handle as well as I'd like. but I think I'm spoiled, b/c my two roomates drive an EVO and an E46 M3.
if I keep the car I might try the tein basics.
Old Aug 19, 2004 | 07:06 AM
Seximus Maximus's Avatar
I have them paired with Tein H-Techs and i use 3/4, i like my suspension kind of stiff. you do feel the bumps but i think handling is excellent. body roll is barely noticed in my mind. with my setting at 2/3 like the person above said its almost like stock. great ride.
Old Aug 19, 2004 | 08:02 AM
phenryiv1's Avatar
Mod her. Ate her.
When posting your settings, please post your spring setup as well. Actually, please post your whole suspension setup, so that we see the whole picture.
It did for me, but it is only noticable at the very edges of handling performance. You will only feel it when you piush your car hard- you will see that it has a wider performance envelope than w/o the RSB, but it also has a sharper cut-off at the handling limits- the margin for error shrinks dramatically.
Old Aug 19, 2004 | 08:34 AM
QuickFast's Avatar
What about the Illumina/Eibach combo? Is anyone running this set-up? If so, how do you like it?
Old Aug 19, 2004 | 08:43 AM
njmaxseltd's Avatar
Funny how everybody runs the rear so firm. With a sway bar and M.V. mounts in the rear I run the rear softer then the front. My ride quality is fantastic (as quite a few on here know) handling is very neutral (thanks to the anti-sway bar).
I run H&R springs with Illuminas set on 3F and 2R.
Those with rear anti-sway bars should lower the rear setting slightly and let the sway bar do some work on the twisties, while getting a much better ride on the highway.
Motivational rear mounts help the rear of our cars absorb bumps, maintain stability and ride quality on lowered setups.
Old Aug 19, 2004 | 09:47 AM
phenryiv1's Avatar
Mod her. Ate her.
MV rears would help, but aren't those out of production now?
Sorry to run OT.
Good points, Tom!
Old Aug 19, 2004 | 09:53 AM
meanbean's Avatar
2 Front / 2 Rear. Very comfortable ride.
Old Aug 19, 2004 | 10:32 AM
VQuick's Avatar
Chassis Freak
You need SOME body roll or agressive driving can be pretty dangerous.
I understood that if you don't have a RSB, you want the rear setting one higher than the front, which is why I have 2/3.
Lol, you can't compare a Maxima to an M3 because the Maxima is so much lighter, of course it's going to feel cheaper... I'm sure the EVO has a stiffer chassis than the 4G Max so if you want a much better feeling car, spend the few hundred dollars to get Warpspeed subframe connectors. I'm planning on that at some point.
Old Aug 19, 2004 | 11:02 AM
vsamoylov
Motivational rear mounts, where did u get those?
Old Aug 19, 2004 | 11:24 AM
Weasel's Avatar
3f/3r with H&R springs. Ride and handling are fantastic, I have a RSB so I keep the rear on 3 and there's still very little understeer at remotely sane speeds. I haven't autocrossed on this setup though, we'll see how that goes.
Old Aug 19, 2004 | 11:37 AM
SPiG's Avatar
SomePsychoGuy
I have Eibachs with Illuminas. 5/5 with no rsb yet, and fstb. Pretty rough but I want that and handle really well.
And yes it is important to tell us your springs.
Originally Posted by maxmods.dyndns.org
Also remember when adjusting shocks, you adjust them for the spring, not for the ride. Too light and your car will rebound and bounce uncontrollably like a car with blown shocks. Too much and your car won't be able to recover from bumps as fast as it should. The ride will be generally bouncy at the lowest setting and will improve as you turn the shock up, and will start to get harsh again near the upper settings. That improved area in the adjustment is where you want to be. Recommended starting settings are shown for each shock, feel free to start from there, and adjust to your spring.
I will probably try 4/4 or 4/5 or something like that but eibachs are supposedly pretty stiff. If someone else has a similiar or preferably exact setup and has had better results with a softer setting please post. I just installed them not too long ago and really haven't tried new settings.
Old Aug 19, 2004 | 11:40 AM
Larry H's Avatar
OK, posting the rest of my mods...
FSTB
Progress RSB
Warpspeed Stage I and II SFCs
I guess my only real complaint is that it doesn't feel like the car is "connected" to the road. I have a feeling I'm close as good as the ride/handling tradeoff is gonna get on an A32 without spending $$$. Maybe the relatively slow steering ratio has something to do with it. I am riding on 18s though.
Tom, regarding your comment, I don't really feel like the back is too stiff, but I'll play around with it and see what happens.
Old Aug 19, 2004 | 12:30 PM
ThurzNite's Avatar
5/5 front/rear
Sprints
that's all I have. Handles like my friend's BMW 325. What was BMW's secret? Was it soft springs and stiff shocks? If so, that's what I have right now. Oh yeah, 17" rims. With stock 15", ride is mushy. Anyways, I'd like to get rid of the sprints... too low, too soft.
I like my ride, except I need a fstb. I can feel the front straining on corner entry. RSB... optional. I like being able to whip the rear around. With RSB, I think I'll need LSD on corner exits. (counter intuitive, but it's my driving style)
Jae
vsamoylov
kinda hard to believe that your car does not feel "connected" to the road after all that suspension mods to it. seems like after all those mods the car should stay glued to the road no matter what. do you think the sfc are worth it though and do you need stage 2 or is stage 1 enough?
Old Aug 19, 2004 | 12:54 PM
ThurzNite's Avatar
My bro's got the bolt-ons too, but no sub frames yet... yes, his car is flat, but boring to drive. There's no communication between traction limit and brick wall. I prefer some "give" in my suspension. oh, and a stiff rear end feels like you got passengers in the back seat... totally un-lively and not fun to whip around... hard to get the car to rotate.
Jae
Old Aug 19, 2004 | 01:09 PM
Larry H's Avatar
Jae
yeah, the car sticks and you can double on ramp/off ramp speeds with no problem; highway lane changes and high-speed sweepers are cake. but the car doesn't really tell you what it's doing or build much confidence. my light pre-97 steering is probably not helping much.
someone asked about the subframes. I put stage I and II on together, so I don't know if stage 1 would have been sufficient. I didn't notice the huge increase in body stiffness that everyone else did, but I did notice that the steering felt MUCH better. kinda like the difference the FSTB made but x3. body roll went down a little and the steering felt much better, especially in highway turns and lane changes.
Old Aug 19, 2004 | 01:49 PM
vsamoylov
man this is strange. you guys make it seem like these bolt-ons are not worth of getting. i mean it seems liike not worth of getting.
what do you guys mean by the car being flat? isnt that the whole purpose of getting suspension mods so the car stays flat during any kind of manuvers?
Old Aug 20, 2004 | 12:15 PM
ThurzNite's Avatar
vsamoylov: Have you driven or read opinions on 350Z's suspension and handling? Some say near perfect, only to understeer at the extreme limits.
With Larry H's setup, I imagine his setup being so much stiffer than a Z, that it's actually harder to find it's limits. It's like, why is the AE86 a great car to learn to drift with? Cuz it's simple... it gives... it's predictable... and it's limits are easier to find. I loved my ex-gf's 93 Altima, tho underpowered, I could maneuver that thing like nothing. All it had was Eibachs, Kyb gr-2, rsb and fstb.
I would suggest you mod 1 thing at a time, over a period of time. I changed my springs first, for 3 months. Then realized I needed shocks. I've been on these shocks for 3 months now, and looking for fstb now. If I had ftsb first, like most people do, I have no idea how the rear end would feel (i'd say unpredictable) and may have upgraded struts next instead of springs. Anyways, it's a learning process.
Jae
Peter Paul
Jan 2, 2016 05:18 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
95Maxi
35
Sep 2, 2015 10:37 AM
