New Battery- New Attitude?
Old Aug 19, 2004 | 12:14 PM
FormorAccordMan's Avatar
Since I bought my car about a year and a half ago, there was some el cheapo "Road Hawk" battery in my car. I came home from vacation, and my car was dead as a stump I jumped the car and drove it to my mechanic to have a battery test, b/c the last time my car stayed at the dealer for a week it was dead when I went to pick it up. I had assumed that they had left the dome light on or something. Didnt think it was the battery. So after the second occurance I figured I would check it out. When I popped the hood, the guys in the shop snickered at my "poor excuse for a battery", Anyhow, I changed the battery out for an AC delco with 730 cold cranking amps. They said that would be fine for a Max. So I drove off, and my car for some strange reason, and I am not imagining this flew like it never did before. Acceleration on the highway was very impressive. My car NEVER felt like this. Can a battery on its last legs affect the performance of a car. My head says no, but my butt dyno says yes. Any thoughts? Even my subs hit tighter.
Old Aug 19, 2004 | 12:50 PM
|Bijan|'s Avatar
UCF Lexus
It's not accelerating quicker...it's a mental thing.
As far as your subs hitting harder, that IS possible. More power (or...FULL power) is of course gona give the amp more juice.
Old Aug 19, 2004 | 12:56 PM
95maxWV's Avatar
if your battery was dying to the point of not producing 12 volts then it can mess with electrical systems but, that usual result in pretty substantial problems.. my parents POS chevy lumina van had this problem twice.. the whole car shut down though.. as soon as the bad batter cell died it fell below the required 12 volts and it shut down.
Old Aug 19, 2004 | 01:49 PM
hmm, maybe it IS in my head., I mean I was driving a dodge caravan rental while i was on vacation. The thing was literally brand new (1600 miles on the odometer) We actually pulled over to check to see if it was a 4 cylinder, but it was a 6! OMG what a POS, And what a racket the engine made when getting on the pedal! It was slower than S!@#. I had forgotten about the VQ!
Old Aug 19, 2004 | 02:26 PM
Pimpmobile's Avatar
I though my max was a rocket after i got my tranny flushed, but it was all in my head
Old Aug 19, 2004 | 03:52 PM
DAVE Sz's Avatar
Hooooooonda.....
Doesn't the battery "stop" working as soon as the engine is running?
Old Aug 20, 2004 | 10:52 AM
No, It is part of the "circuit".
Old Aug 20, 2004 | 11:33 AM
95maxWV's Avatar
yeah.. if it stopped then it wouldnt matter when your alternator died.. you would still be able to drive wherever as long as you didnt turn the car off.. but we all know that doesnt happen...
Old Aug 20, 2004 | 11:38 AM
RA030726's Avatar
I'm nutty for Nissans
Once the car is running the battery is just charging. The alternator is doing all the electrical work. You can test an alternator by unhooking the battery. If the car dies then the alt. is junk. of course with a big stereo the battery is being used most of the time.
Old Aug 20, 2004 | 12:43 PM
NightRider's Avatar
PLEASE DO NOT DO THIS!!!!! I can't stress that enough. That may have been a trick in the 70 and 80s, but in today's modern cars you run the risk of frying your ECU or other computer components. Your battery also acts as a capacitor that helps the alternator regulate DC current. When you unplug it, it will only be running from the voltage regulator, which is more like a rectifier. You'll be running AC current on a system that only accepts DC current.
When the car is running the battery is not "just charging".
A bad battery DOES affect performance in a car..especially if it has an ignition system as sensitive as ours. Otherwise, grounding systems are useless, right? Your spark plugs get power from your coils. Your ECU calculates by moving electrons. Where do they get power from? The more steady power your ECU has the faster it can calculate. The more power your coils have the stronger the spark. Your electrical system is the most important item in your performance arsenal. If is wasn't, spark plugs would never be changed.
The alternator is doing all the electrical work.......of course with a big stereo the battery is being used most of the time.
You are contradicting yourself.
Old Aug 21, 2004 | 07:00 AM
QUOTE
I was thinking this when I was brainstorming aas to why my car seemed to have gained performance. It does make sense.
Old Aug 21, 2004 | 09:17 AM
datguyclark's Avatar
yea oulling the terminal off the battery while its running only works on the old azz beaters...not on newer cars...serious problems can occur
xHypex
Mar 20, 2003 10:30 AM
Speebs
Nov 26, 2002 12:04 PM
