Running power to battery... how?
Old Nov 25, 2002 | 06:24 PM
Speebs's Avatar
I aim to misbehave.
I am hooking up some aftermarket foglights and plan on getting a Basslink in the near future. I know that both of these will need to be attached directly to the + terminal of the battery- can someone tell me the best way to attach more wires to the terminal? Thanks!
Old Nov 25, 2002 | 08:07 PM
MIXXMAX's Avatar
Actually, you can just attach a ring terminal on the end of each wire and attach it on to the screw/bolt of the positive battery.
Old Nov 25, 2002 | 09:16 PM
Speebs's Avatar
I aim to misbehave.
Yeah, I figured that would probably be easiest.. I was just wondering if there was a "cleaner" way to do it. Thanks!
Doug
Old Nov 25, 2002 | 09:40 PM
ThurzNite's Avatar
You can try to run 1 wire from the battery to a distribution block that you place beneath the black fusebox (to the right of the battery if you're looking from the front of the car). There's plenty of space there to mount a distribution block. I might do this...depending on how much more electronic junk I wanna put in my car.
Jae
Old Nov 26, 2002 | 01:04 AM
TL@altimas.net's Avatar
this is how my battery is set up: http://images.cardomain.com/installs...92_51_full.jpg
I have a small barrier strip in my kickpanel too for accessories..
Old Nov 26, 2002 | 08:55 AM
spta97's Avatar
Nice setup. What gauge wire is that?
It seems like you didn't have to cut the factory terminal ring in order to use the after market one. Is that correct?
Oh, if you have a description of the picture I would love to see it.
Old Nov 26, 2002 | 12:04 PM
thanks
I have 0 guage running from the alternator to the battery, and 2 guage running back to the amps.. Alternator, engine block, & battery ground are all 1/0..
the wires on the sidepost are the stock connections.. I was able to turn the stock post clamp into a ring terminal with a couple strategic hammer blows & a little grinding then I just put rings on the other 2 10 guage stock wires and hooked it up on the side to keep it outta the way..
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
captchaos
Mar 15, 2016 12:18 PM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
