TEIN spring CAN'T handle 20" wheel
Hi guys! I just dropped my Max with TEIN S-tech spring and KYB gr-2. The look is awesome and the ride is just a bit stiffer than its original SE Springs with 16" wheels. However, when I installed a new set of 20" wheels (245/35/20) then the problem starts. With the 20" on the Max, it has only less then an inch clearance between the tire and the wheel well lip on the front. It's doing just fine on smooth road but the FRONT wheels are constantly rubbing the inner fender lips when it rolls on an uneven road, or deep rainstorm curve. Any of you guys have the same problem as I do with 20" wheels. Man, I love the look of the S-tech drop paired with 20" chrome. What are my options here?
1. Keep the S-tech and run it with 16" wheels, or...
2. Go with Eiback or H-tech and run it with 20" wheels
Don
Don
Don
Don
Your problem is probably due to improper wheel offset and/or size of tire.... H tech are even softer than the S.
Think about it... you should have more than 1" travel for safety reasons.
Originally Posted by max****
no advice but i want pics of your car.. NOW
OK guys! A buddy of mine will be here in Orlando tomorrow to try on the 20" wheels with his Eibach/KBY-GR2 set-up to see if any rubbing problems. I got this set off a Lexus guy for a great deal, the tire profile is already too low for my taste, so don't wanna go any lower as some of you recommended. If it works fine with Eibach then I might want to trade the S-tech for eibach b/c I love those 20" chrome sooo much. Thanks you all for your inputs.
imported_Nismo_max
02-17-2016 03:39 AM
Hdnseek
09-09-2015 05:55 AM
