New PADS, New ROTORS, Balanced TIRES. still alot of noise !
Old Aug 19, 2004 | 06:22 PM
VIP Maxima
raybestos quitestops, brembo xdrilled/slotted rotors, installed 150 miles ago and still alot of noise !
road noise when rolling and noise when braking !
my good year's are extremly noisy when im driving and on top of that, new pads and rotors didnt quite down my ride at all. i still hear this kinda GRINDING noise when i hit the brakes. what can i do to get rid of this annoying brake noise? is it normal??
Old Aug 19, 2004 | 08:23 PM
aznsap's Avatar
i think i see the problem....
Originally Posted by 98MikeXimaSE
raybestos quitestops, brembo xdrilled/slotted rotors, installed 150k miles ago and still alot of noise !
your brake pads probably worn all the way down to the metal so it's grinding now.
Old Aug 19, 2004 | 08:50 PM
VIP Maxima
i meant 150 miles ago lol
Old Aug 19, 2004 | 10:22 PM
Prophecy1's Avatar
What size wheels and what type of tires. SOme tires are loud and bigger wheels are louder than stock.
PRoph
Old Aug 19, 2004 | 11:27 PM
VIP Maxima
stock se rims on good year's. my main concern is the grinding noise when i apply the brakes
Old Aug 19, 2004 | 11:38 PM
chuckie311's Avatar
try to readjust your caliper maybe they are to close to the rotors and grind when they spin.. just a thought
Old Aug 20, 2004 | 05:04 AM
njmaxseltd's Avatar
It's your tires making the noise not your brakes.
Old Aug 21, 2004 | 02:01 PM
VIP Maxima
but i hear that grinding noise when i hit the brakes, its the tires?
Old Aug 21, 2004 | 04:37 PM
njmaxseltd's Avatar
Grinding or a worrr worrr worrr worrr noise?
Your complaint is noise both rolling and while braking. You just put all new brakes in, the only other thing left is the tread on your tires. Tire noise is sometimes difficult to diagnoss. It's often confused with wheel bearing noise. Bearing noise comes and goes with side to side load. Tire tread noise at highway and low speeds or while braking is more of a sound or note rather then grinding of two hard objects.
Exactly which tire is on your car? H, W, or Z rated?
How many miles are on them and have then been rotated correctly?
A bad front end alignment can cause cupping of the tread which will definalely make your tires humm an annoying note.
Old Aug 21, 2004 | 11:27 PM
VIP Maxima
they are good early eagle high performance summer. im not sure what the rating is. the noise is more like "worr worr worr" as u called it. my tires have about 12000 miles on them. the noise i hear during braking is different than the tire noise....
Old Aug 22, 2004 | 07:40 AM
njmaxseltd's Avatar
Take the brakes apart and check everything. It's not hard, should take you less then 1 hour to check the whole car. After then put a different set of wheels and tires on (borrow a buddies) and see what it sounds like.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
NmexMAX
May 23, 2016 07:38 PM
Socalstillen
Sep 26, 2015 12:01 PM
