Clutch Bleeding Help!!!!!
Old Aug 19, 2004 | 08:37 PM
Nismo3112's Avatar
Custom User Title
Hey.. I'm doing a 5spd conversion, and have everything hooked up.. So today I went ahead and bled the clutch. But for some reason. It keeps NO pressure.. I bleed until there are no more bubbles, and then tighten the bleed screw, same for the upper bleeder. But the clutch stays on the floor, and does not come up. We tried bleeding over and over but same results... Someone please help!!!! Would anyone's guess be that the clutch master, or slave is leaking?? I checked and double checked all the lines, but no leaks. Any help is appreciated.. Thanks.
Old Aug 19, 2004 | 08:54 PM
KFL's Avatar
KFL
Whats your bleeding procedure exactly.
If the slave/master was leaking some fluid would appear after working the clutch with your hand the build up of pressure.I've seen the slave go bad and then the clutch lies downward.
Old Aug 19, 2004 | 09:07 PM
Nismo3112's Avatar
Custom User Title
Okay my procedure is:
I top of the master clutch cylinder..
hook up a hose to the lower bleeder..
Have assistant inside car press down on the clutch pedal..
Loosen the valve.. then close it..
I tell the assisstant to pull the clutch pedal up.
We Repeat these steps until no more bubbles are noticed.
Same with the uppper bleeder.
Somethin tells me my procedure is wayy wrong..KFL?
Old Aug 19, 2004 | 09:19 PM
JeEvE's Avatar
After your done bleeding, try to pull up the pedal and push it down. Repeat this until the pedal come back on its own. I thought I had no pressure either until I did that and its been working fine.
Old Aug 19, 2004 | 09:24 PM
Nismo3112's Avatar
Custom User Title
I will try that tomorrow.. I got worried that I would have to replace the clutch master, and slave.. But I will try that tomorrow ASAP. BTW.. You do that AFTER there are no bubbles in the lines right?
Thanks so much for the reply.
Old Aug 19, 2004 | 10:22 PM
MikeB's Avatar
I have had similar experience with hydraulic systems on other cars. You probably want to do the slave first, then the master, following a procedure of pushing down on the clutch , letting air out, tighten the fitting, then tell assistant in the car to pull up slow on the pedal. I fyou can't get it right after awhile do suspect the slave. My experience is used units especially if they've been sitting around in a junk yard, are problematic due to rust, moisture problems.
Old Aug 19, 2004 | 11:08 PM
Nismo3112's Avatar
Custom User Title
How do you bleed the master? Is it the bleed port mounted on the left strut tower?
Old Aug 20, 2004 | 07:54 AM
Stephen Max's Avatar
Hmmm.
This makes me worry there may be a problem with the actuator arm/throwout bearing/pressure plate assembly. Do you know for sure that the slave cylinder plunger is contacting the actuator arm? Is force being transmitted through the actuator arm and throwout bearing to the clutch pressure plate when you step on the clutch?
Old Aug 20, 2004 | 10:45 AM
Nismo3112's Avatar
Custom User Title
the slave goes out, but it seems that it doesnt go out far enough... it touches the throwout bearing arm, and moves it a little bit, but not nearly enough. When I have my helper hold the clutch pedal down, I can push the slave plunger back in, which means its not holding pressure? Also, I looked up under the clutch pedal, and where the clutch master comes in, theres a slight sweat on the grommit boot.. I am guessing I need a new master cylinder. Any thoughts?
Old Aug 20, 2004 | 12:29 PM
Nismo3112's Avatar
Custom User Title
Bump... Anyone??
Old Aug 20, 2004 | 12:35 PM
ThurzNite's Avatar
I use a vacuum thingy to bleed... so 1 person job. I don't kno if that will make a diff.
Jae
Old Aug 20, 2004 | 12:45 PM
I'm thinking it's a problem with the master cylinder, too. When a slave cylinder goes out, it leaks. When a master cylinder goes out, you don't get leakage, you just don't develop enough pressure to move the throw out bearing arm. Did you buy a used master cylinder? A new one isn't too expensive.
Old Aug 20, 2004 | 12:52 PM
Batxel's Avatar
blah
Something that I didn't see anybody else say... Make sure you keep the master cylinder full through this whole process. Only open the bleeder valves for a second or two. Make sure your banjo bolts are on tight; best if you use the specific torque specifications.
Old Aug 20, 2004 | 01:18 PM
Nismo3112's Avatar
Custom User Title
I will be replacing the Master with a new one, the one I have on there now is used. Anyone know if I used say a hyraulic line from a eclipse (straight hard line), so I would basically have one single line going from the master to the slave.... it will eliminate the upper bleeder, but will it have any side effects?
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
