Door Panel help
Old Aug 20, 2004 | 06:25 PM
Maxima Mike
Door Panel help
How do I get my door panel off? I can't get to my speakers, and I heard that you need a special tool to get to the lock.
Old Aug 20, 2004 | 07:18 PM
GarciaMaxima's Avatar
No special tool required. Once you get the bottom screws out everything else pretty much snaps out. I had a little trouble with the trim around the door handle, but that just clips out as well. Use a flat head screw driver and pry it out from the top and bottom not the sides.
Good luck
Old Aug 20, 2004 | 07:22 PM
95bkackmax18s's Avatar
yea, preatty much what he said, two screws on bottom,
a screw in the little hole for where you grab the door from the inside( not sure what you would call it) and the trim around the inside handle which i thought you pull and pry to the right or left and then just pull the panel evenly from the bottom and work your way up.....
99se5spd's Avatar
you can take a putty knife and cut half of it off and smooth it up real good, its a great tool for removal of all interior trim. another is to take a flat head screwdriver and put a slight bend to the tip and smooth it out. either one will leave less or no marks on your trim during removal
Old Aug 20, 2004 | 07:26 PM
It might be right and left side, I cant remember its been too long.
Old Aug 20, 2004 | 07:30 PM
yea that part ( trim around handle) was rough for me, i cracked the top half on the rear passenger side, but a little super glue and its fine now
Old Aug 20, 2004 | 07:56 PM
Maxima Mike
Figured it out. Thanks for the replies everyone. Yeah the only thing I had trouble with was the handle.
Circuit City wanted to charge me $33 to install these speakers I bought, and the guy told me I needed a special tool, and they also told me it'd take an hour It only took me 20min to install the speakers.
Old Aug 20, 2004 | 07:58 PM
good, good, good, glad to hear
Old Aug 20, 2004 | 09:36 PM
OneToughMax's Avatar
circuit city installers are hacks. none of them at any of their locations nationwide have any idea what they are talking about.
oops - did i post that out loud?
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
