Sunroof leaking
Old Aug 21, 2004 | 06:41 AM
Tomegun's Avatar
Sunroof leaking
I have a 96 SE with a leaky sunroof. Has anyone had any problems with the sunroof and if so how much does it normally cost to get it fixed?
Old Aug 21, 2004 | 08:24 AM
99se5spd's Avatar
the drain tubes are probably clogged. use compressed air to clean out the front ones, open the roof and in both front corners you will see holes and just blow it in there. for the back ones remove or pull back the side trim in the trunk and locate them (they should be clear about 3/4" diameter) and pull them out the hole they are in and clean out the ends. hope this helps
Old Aug 28, 2004 | 04:56 PM
Tomegun's Avatar
Can someone describe, in more detail, how to find the tubes in back? I couldn't locate them. Thanks.
aw11power
Oct 10, 2021 04:57 AM
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
