CEL, 1003? PARK/Neutral Switch?
Old Aug 24, 2004 | 04:50 AM
sean05's Avatar
hey guys,
my favorite light popped on yesterday, CEL So i got the ECU code and it come out with 10 long and 3 short, PARK/Neutral Switch? Does anyone know how to fix this? What does it do? What triggered it? Is it bad to drive it with the light on.
thanks
Old Aug 24, 2004 | 11:58 AM
sean05's Avatar
BUMP plzzz
Old Aug 24, 2004 | 03:33 PM
ThurzNite's Avatar
Do you have 5sp or auto?
Jae
Old Aug 24, 2004 | 03:54 PM
Nismo's Avatar
I have this too, cant figure it out also,(5speed conversion)
Old Aug 24, 2004 | 03:58 PM
BEJAY1's Avatar
Conecarver
Mine's on too (5sp). One problem with it is that the white reverse lights won't function making it dangerous when backing up. It's pretty much just a switch on the bottom of the tranny that you probe, test, and swap. Haynes doesn't describe it too well but the FSM's cover it.
Old Aug 24, 2004 | 04:37 PM
BradsMaxima's Avatar
OKay I just did this little swap its actually really easy. Its like a 40 dollar part at nissan. Theres one bolt holding the switch on the bottom of the trannyit just pops out. I had to take it off in pieces cuz it was so stuck on there. But be prepared when that switch comes off about 4 litres of fluid comes with it, so either drain it before hand or have a container ready. Theres also a switch that comes with the packageit goes inside the tranny. This is the hard part. I tried to take it off iwth my fingers so I dropped it in the tranny. And when I tried to get it out I ended up pushing it back farther. but I covered the hole and put some gear oil in there and it came to a point where I fished it out. So I would take the little switch out with some pliers or something just so yu have a good grip on it. Then it goes all back together the way it came off. Just send me a private msg if you need more help.
Old Aug 24, 2004 | 07:02 PM
sean05's Avatar
i have a 5 speed. So our reverse lights dont work? hum...
Old Aug 25, 2004 | 12:42 PM
If your reverse lights dont work and you tried changing the bulb then its becuase of this switch. Mine worked fine after.
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
