help! what else should i check??
Old Aug 25, 2004 | 01:02 PM
MaineMax97SE's Avatar
alright, need some suggestions. I know I need a new rear 02 sensor. My car doesn't have the acceleration it did before my check engine light came on. bad gas mileage, low rpm power loss. i know i should replace the sensor and then see what that does but in case it does nothing, what else should i check to address my acceleration issue?
thanks.
Old Aug 25, 2004 | 01:04 PM
VIP Maxima
fuel filter, air filter, tire pressure, balance ur tires. check for KS code, check sparks. clean tb. hmm what else?
Old Aug 25, 2004 | 01:21 PM
alright thanks.
Old Aug 25, 2004 | 01:31 PM
RA030726's Avatar
I'm nutty for Nissans
I bet its the knock sensor, but if the O2 sensor code is present change it first. Then if the KS code shows up then you know 100% its dead. The KS code comes up when other things are messed up, such as O2 sensors....but it will never light the MIL.
Old Aug 25, 2004 | 05:59 PM
replace which one?
alright, so i had the dealer check the codes just to be sure and they said it was the rear o2 sensor too. but....i got the 34 code too which is the knock sensor right? so should i replace the knock sensor first or the sensor? or both?
thanks
Old Aug 25, 2004 | 06:15 PM
99se5spd's Avatar
like maxima10to1 said, replace the o2 sensor first, reset ecm, and drive it for a week or so than check the codes again, if knock sensor code it there again than replace it. sometimes when other sensors go bad it throws the knock sensor code also
Old Aug 27, 2004 | 05:23 AM
so replace o2 first?
So it's possible that my KS is ok but since my rear 02 sensor (7,7code) went bad, it might have tripped my KS code too? I'm thinking maybe I should replace the KS anyway since it hasn't been done in 4-5 years but if just replacing the 02 works than I wouldn't worry about the KS for a little while.
thanks.
Old Aug 27, 2004 | 12:56 PM
RA030726's Avatar
Every time my 96 got an O2 code it tripped the KS too. I would replcae the O2 1st, but if you have the money go nutts are replace the KS too. Come to think of it, the rear O2 checks to see if the cat is working and should not affect performance. My gut says the KS is junk too.
Old Aug 27, 2004 | 01:42 PM
Yeah, I'm thinking the KS is bad too. So I'm going to replace both.
maxinout93
Oct 31, 2015 02:04 AM
magiconthetire
Oct 26, 2015 09:03 PM
salty318
Sep 29, 2015 01:21 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
