MANUAL tranny drain bolt!!!!!!!!
Old Aug 27, 2004 | 12:31 PM
p00tan6's Avatar
Where is the manual tranny drain bolt at?? The only think i see at the bottom of the tranny is a Flathead type screw. I unscrewed a bolt near the fill plug, but only a little bit of fluid came out. Please help!!
Old Aug 27, 2004 | 12:37 PM
way2fast95's Avatar
Stop me if I'm wrong ( and I might be), but manuals have tranny fluid? They didn't used to did they? Mine has a hydro. clutch that has fluid, but the tranny?
Old Aug 27, 2004 | 12:52 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
the gear fluid drains through a 14mm bolt - follow the support rod to the tranny, and it sits in between the two bolts where it attaches to the case. The bolt is positioned parallel to the ground
Old Aug 27, 2004 | 01:09 PM
way2fast95's Avatar
Crap, is this something that we need to drain and or check the level on regularly? I haven't ever checked mine, whats the recommendation?
Old Aug 27, 2004 | 01:26 PM
DAVE Sz's Avatar
Hooooooonda.....
Check in the FLUIDS forum, that's why it's there.
Old Aug 27, 2004 | 02:06 PM
p00tan6's Avatar
I believe its a 12mm bolt way at the back of the tranny and there is a metal piece to the side of it that makes it hard to take off with a socket set. I had to use a wrench because a socket couldnt fit in. Correct me if i'm wrong.
Old Aug 27, 2004 | 02:21 PM
MaximaNewb's Avatar
From what I remember It's hard to find... And we had to pump the fluid into it... Pain in the butt if you ask me I would have a shop do it if its not too much $$$
Old Aug 27, 2004 | 04:14 PM
Ladzio's Avatar
I drain tranny by the means of unplugging reverse position sensor.
Old Aug 27, 2004 | 05:27 PM
bearded's Avatar
You gotta be very careful when doing this because the sensor is very delicate, plus you might also get a leak. I replaced my sensor at the same time that I changed to redline mt90 gear oil.
You do know that there is a fill plug too right??? You can just pour the fluid in from the engine bay with a funnel.
Old Aug 27, 2004 | 06:07 PM
DAVE Sz's Avatar
Hooooooonda.....
The fill plug is about 2/3 way up the trans case facing the front of the car and the drain bolt is at the bottom of the trans facing the firewall. FLUIDS and LUBRICANTS forum has the pics abd everything you'll need to know.
Old Aug 27, 2004 | 07:01 PM
Terran's Avatar
http://vbxmaxima.8m.com/mtoil.html
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
Forge277
Jun 13, 2016 09:26 PM
