changing thermostat any advice??
Old Aug 27, 2004 | 05:22 PM
maximus_pr's Avatar
any advice already cleaned the radiator due to a repair 3 days ago i bough the oem stat today to my surprise it came with the housing is this normal also the dealer told me it don't use a gasket it use pvc silicone sealer its this true?
Old Aug 27, 2004 | 08:22 PM
matty's Avatar
The entire housing is normal, should have only been $14-$16 if ya didnt get ripped off. its really nice unit considering all the local Auto parts stores want $30-$35 for the same thing.
NO dont use silicone sealer....Buy that gasket from nissan and use that only...They put it on there from the factory for a reason right ?
as for advice, change out the bottom hose while your at it
-matt
Old Aug 27, 2004 | 08:48 PM
maximus_pr's Avatar
i did ask for the gasket they told me theres none anyone knows part#
Old Aug 28, 2004 | 10:38 AM
rlin78's Avatar
I just reused the old gasket and it sealed well. By the way, the gasket is metal in case you want to know. The one came with the OEM replacement I got from Autozone was paper, didn't work well while putting it, I had to reuse the old one.
Old Aug 28, 2004 | 10:56 AM
maximus_pr's Avatar
waiting tilt tomorrow because i need more info on this subject don't want to change it to end up with a leak
Old Aug 28, 2004 | 11:20 AM
SkinnyMax's Avatar
maxima no more
I just used the paper one that came with the replacement t-stat, has worked fine for 9 months now, you just need to make sure that it is alligned properly and doesn't get folded over on itself
Old Aug 28, 2004 | 12:37 PM
matty's Avatar
The information I gave your Valid...I just put my S/C Kit in with an upgraded thermostat housing and it doesnt leak one bit..
Buy a New gasket ($2-4) and replace it...If Nissan tells you they dont have one, tell them to order it in
-matt
Old Aug 28, 2004 | 12:44 PM
maximus_pr's Avatar
ok thanks for your help guys guess i have to wait until next weekend to do this so i can buy gasket someplace else monday
Old Aug 28, 2004 | 05:52 PM
69CHARGER_RT's Avatar
I agree there is a gasket. I changed mine recently when I did my waterpump.
Buying a lower hose as well is good advice....
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
RWCreative
Sep 21, 2015 11:01 AM
97_GXE
20
Sep 17, 2015 08:12 PM
aminus21
Sep 12, 2015 04:53 PM
