how hard/long to change out KNOCK SENSOR?
Old Aug 28, 2004 | 03:19 PM
Jonny98max's Avatar
how hard and how long did it take u to change out ur knock sensor?
Old Aug 28, 2004 | 03:28 PM
happyricefob's Avatar
V^___^V
http://www.motorvate.ca/mvp.php/507
not too hard.
Old Aug 28, 2004 | 03:32 PM
Conrad283's Avatar
I need a truck
Not too hard, but just incase you need to stick your hand in there make sure the engine block is cool. I was just like "**** it" and stuck my hand in there even though the engine block was hot.
Be patient and it can be done in less than an hour.
Old Aug 28, 2004 | 03:47 PM
PAREDLINE's Avatar
There's a way to get a wrench in there to loosen it. Then you can use one of those flex socket extensions and pull the thing off.
I think the official way in the manual is to take off the intake plenum. You can do that too. Good excuse to clean it out
Old Aug 28, 2004 | 04:21 PM
f550maranello2's Avatar
it took me some where between 3 to five minutes maybe even less get 2 swivels and a couple of extencions and remover the air cleaner it will make it much easier
Old Aug 28, 2004 | 05:56 PM
ThurzNite's Avatar
plenty of threads recently, on knock sensor. Here's how I did it with a combo wrench and rachet extension: http://thurznite.maximaclubca.com/pi...%20Sensor.html
Jae
Old Aug 28, 2004 | 06:25 PM
bigx323's Avatar
took me about an hour which included going to the store to pick up the flex socket
installing took the better half of the time
Old Aug 28, 2004 | 07:01 PM
BlackCat's Avatar
RIP '98 Maxima SE
Took me about an hour. Did the 12mm universal joint/extension bar thing, used my special coat-hanger wire to lift up the sensor and tugged on the wire to pull it out.
bbsitum
Sep 6, 2019 07:31 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
