knock sensor replacement cost?
Old Aug 30, 2004 | 12:33 PM
MaineMax97SE's Avatar
For anybody that's had their knock sensor replaced by a dealer or shop, how much was it?
Old Aug 30, 2004 | 01:08 PM
|Bijan|'s Avatar
UCF Lexus
haha......they wouldnt be posting here cuz they wouldnt be able to afford internet anymore.
Try your hardest to DIY......if not, see if a local member can help you out.
Old Aug 30, 2004 | 01:15 PM
mzmtg's Avatar
Minister of Silly Walks
The book rate for Nissan dealers is over $300 I believe.
NmexMAX's Avatar
dot dot dot ...
About 500+ with parts and labor, just take the 15 minutes to do, its not that hard, breaker bar and a 1/4 ratchet and some bloodshed, its not that bad.
Old Aug 30, 2004 | 01:41 PM
ThurzNite's Avatar
Bloodshed is critical. w/o it, you're SOL.
pics on my site, under random pics/maxima.org
Jae
Old Aug 30, 2004 | 01:44 PM
mzmtg's Avatar
Jae
I still have a scar from where I burned my hand.
Tip from old uncle mzmtg: Let the engine cool off completely.
Old Aug 30, 2004 | 01:56 PM
BlackCat's Avatar
RIP '98 Maxima SE
Jae
That's not true anymore. You gotta read my thread!
http://forums.maxima.org/showthread.php?t=333236
To give you an idea of my hand size I usually wear a medium to large size when wearing those disposable latex gloves.
With the instructions here it wasn't so bad to do it yourself.
http://www.motorvate.ca/mvp.php/507
Old Aug 30, 2004 | 06:47 PM
ThurzNite's Avatar
I read your thread a few days ago. I was just pokin fun @ myself. Heehee. The only lube I got around here is K-Y. Will that work?
Jae
Old Aug 30, 2004 | 07:19 PM
spk's Avatar
spk
So after reading all about the KS today, I decided to check out my newly acquired 96 SE, and there it was, the 0304. Sweet!
Checked the resistance, and it was 562 kOhm. Ok, so I went and ran it hard through up through the top end of 4th from a stop , and it felt fine (but I haven't had it too long, so I don't have a real reference point).
Got home and reset the ECU, but I still got 0304.
Anything else I can check before I bite the bullet and take it to a shop? Does it have to be a Nissan dealer, or would my friendly/good local mechanic be able to get more info? I'd really rather not take it to a shop, but I dunno how much just having them run the diagnostics would cost me. $50? I'd almost rather replace the sensor for $75.
Any help is good. Thanks.
Old Aug 31, 2004 | 07:26 AM
Matt93SE's Avatar
STFU n00b!
where can you get one for $75?
Old Aug 31, 2004 | 07:38 AM
Tort's Avatar
Replacing the KS is easy, everyone should do it themselves. Im a big guy with big hands and I replaced mine in under 30 mins. I found it easiest to use a long box wrench and a screwdriver to help with the leverage. I also removed my EGR solenoid to give a little more room which is only held on by one bolt and a couple vacuum lines. Save yourself the money, do it yourself.
Old Aug 31, 2004 | 08:00 AM
BlackCat's Avatar
RIP '98 Maxima SE
Jae
K-Y is a good idea but it would'nt work as its incompatible with rubber things (eg. hoses, condoms, etc).
Don't get discouraged! I was getting frustrated and almost went to the stealership until I tried loosening it again and was successful.
Old Aug 31, 2004 | 08:36 AM
Matt93SE's Avatar
STFU n00b!
I wish it was that easy on the VE. you have to remove the upper and lower intake manifold, and the water pipe running through the V in the block.. might as well change the water pump while you're in there, cause you have half the bolts off already. it's a 6-8 hour job.
I'm just gonna bolt that biatch to the front of the block instead of tear the engine apart.
Old Aug 31, 2004 | 08:38 AM
|Bijan|'s Avatar
UCF Lexus
^ aint that aboutab*tch?
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
