Grounding kit???
Old Aug 31, 2004 | 09:52 AM
97maxxx's Avatar
Grounding kit???
i have read a little bit about the grounding kits for our fourth generation but they were all mixed reviews-does anyone have a grounding kit on -do you really feel the difference? please post your opinion on this -also if they do work like they say they do what points do they exactly hook up to ? thanks in advance
Old Aug 31, 2004 | 11:11 AM
97maxxx's Avatar
anyone?????
Old Aug 31, 2004 | 11:17 AM
Jeff92se's Avatar
I'm needing a caw
Exactly which reviews have you "read"? Please list them and I'll review them for ya.
Old Aug 31, 2004 | 11:32 AM
Keyser Skoze's Avatar
I have it. As for a power increase i say thats imposible. Call me crazy but i think my mpg did increase a little but not much. I think its more for looks then anything else.
Old Aug 31, 2004 | 12:11 PM
DAVE Sz's Avatar
Hooooooonda.....
Everything's possible. If your car's ground points are rusted to hell putting in new grounds could do wonders. As for a grounding kit, go to sears or any place that sells those orange extension cables. Buy those and some connectors and you got a grounding kit.
Old Aug 31, 2004 | 12:13 PM
97maxxx's Avatar
where exactly are the grounds points i heard there are really only 4 or 5 true points and the rest are just a waste let me know thanks
Old Aug 31, 2004 | 12:35 PM
Tyrexx's Avatar
Red 8 Ga. subwoofer wire + Solder + Regular Connecters = Grounding Kit
My Ground spots: Driver headlight ground point, Pass headlight ground point, TB, IM, Engine Block, Alternator, KS ground point, Strut tower, firewall
Yes, i'm sure some of those are useless ground points, but why throw away the extra wire?
Old Aug 31, 2004 | 01:46 PM
got the same on mine.
Old Aug 31, 2004 | 01:51 PM
1FSTMAX's Avatar
I thought about doing this mod, but i think having wires all over the place looks nasty.
Old Aug 31, 2004 | 01:59 PM
RA030726's Avatar
I'm nutty for Nissans
I just read an article in a mag, they had a 350z with some big name grounding kit. They did before and after dynos. And guess what? It had a power increase. Something along the lines of +4 ftlbs and +3-5 hp. Crazy! But I do believe it. On orger used the HKS kit and dynoed something like +7 hp. I have a homemade kit. It looks neat, adds color, helps the electrical system, and adds power too. I dont feel the gains, but I really like the look so its all cool in my book.
Old Aug 31, 2004 | 02:51 PM
happyricefob's Avatar
V^___^V
i have HKS hyper grounding kit. my ground spots are: knock sensor, headlights, and throttle body.
Old Aug 31, 2004 | 02:54 PM
Jeff92se's Avatar
I'm needing a caw
Ummm throttle body? You are missing the alternator and coils
Old Aug 31, 2004 | 03:20 PM
bruteMax's Avatar
BlehmCo's grounding kit is simple and all you need. $45 iirc. Designed specifically for the 4th gen.
Old Aug 31, 2004 | 06:22 PM
GarciaMaxima's Avatar
Do you have a link for the BlehmCo's kit?
Old Aug 31, 2004 | 06:25 PM
ManualMaxima's Avatar
5th Gen till she dies!
i have heard it does wonders for your idle
Old Aug 31, 2004 | 06:31 PM
MDeezy's Avatar
can anyone make a write up on how we can do this mod, cause if this grouding kit can save my tails lights from going out (2nd time for no reason) then I'm all for it, plus if it give some gains and helps idle.
thanks
Old Aug 31, 2004 | 06:37 PM
bruteMax's Avatar
http://www.mattblehm.com/
MDeezy:
you have a short somewhere, probably in the bulb harness. A grounding kit isn't going to circumvent this. A grounding kit at most maintains a smoother idle. It is more a preventative measure than anything else.
Old Aug 31, 2004 | 06:41 PM
MDeezy's Avatar
bruteMax,
I'll check it out, I reused old bulbs and then went out, so I'll try brand new ones and if it goes out then I do.
Also is there a way I can check with volt meter to check and see? or would it just be better to get a new bulb harness.
(mumbling: this things I have to fix seems to never end. . .)
Old Aug 31, 2004 | 07:38 PM
my99maxisnice's Avatar
Tyrexx:
Which bolt on the alternator is the ground? I want that grounded most of all, but haven't seen a write up with that included...
Old Sep 1, 2004 | 07:10 AM
sagamax's Avatar
Give me a Bud Light Holmes
ive always wondered about if this mod is worth is....when i get some extra money layin around i will eventually get it
Old Sep 1, 2004 | 10:51 AM
97maxxx's Avatar
so can anyone show exactly where the grounding points are with pictures or something because i dont know exactly where to do it to the alternator thanks
Old Sep 1, 2004 | 11:31 AM
1MAX2NV's Avatar
It does add HP/TQ. It has been dyno proven by various magazines and individuals.
As for correct grounding points, get a FSM. All factory grounding points are layed out in a diagram. I just piggy backed on all the factory grounding points plus a few more that helped my aftermarket gauges read more accurate.
My pictures. I took pictures of most of the grounding points.
http://public.fotki.com/1max2nv/1max..._earth_system/
Old Sep 1, 2004 | 11:43 AM
Mr.Duck's Avatar
can anyone post where i could get a GOOD but CHEAP grounding kit?
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
