Need Help ABS light stays on (97 MAX SE)
Old Sep 1, 2004 | 08:59 AM
unixsvr4's Avatar
Just recently I am having problem with ABS light stays on, when I first startup in the mornig the ABS light stays on and when I restart again the light goes away. I am not sure what the problem is. Any help would be really appreciated.
Old Sep 1, 2004 | 10:34 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
make sure your car has enough juice to power the abs. check your battery.
Old Sep 1, 2004 | 10:52 AM
unixsvr4's Avatar
Thanks for the tip, but battery is hardly a year old. Any thing else we can try.
Old Sep 1, 2004 | 10:53 AM
Jeff92se's Avatar
I'm needing a caw
Run abs diagnostics. Probably a bad abs sensor (or it's dirty)
Old Sep 3, 2004 | 08:03 AM
unixsvr4's Avatar
running ABS diagnostics means ECU reset and check the codes. Now where is ABS sensor located, I can certaily try to clean it or something, thanks.
AnsonJ
Jun 2, 2017 01:35 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
rbaker100
Aug 28, 2015 08:11 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
2k0to2k3
Aug 18, 2015 09:59 AM
