parking brake sticking
Old Sep 2, 2004 | 07:28 AM
Asleeper's Avatar
I know this tends to be a common with the Maxima's. The question is...what parts do I need to fix this problem?
BTW the car is a 97 SE 5spd.
Old Sep 2, 2004 | 07:34 AM
NmexMAX's Avatar
dot dot dot ...
Explain your problem a little further? But to loosen the brake, just get under the car locate the spring with the cable mounted to it, and free up some slack.
Old Sep 2, 2004 | 07:54 AM
Dr.Monkey1313's Avatar
On my 96 I 30, my rear left brake was sticking. I checked it out and it turned out to be the rear left caliper. I switched it out and all is good now. Do you think this might be a similar problem to what you are having?
Basically the caliper boot had cracked and let moisture in so the thing rusted up and would not depress anymore. It was a pretty easy thing to take care of.
Old Sep 2, 2004 | 07:58 AM
NmexMAX's Avatar
dot dot dot ...
YEah sticky calipers happen to 4th gnes a lot too, I've replaced my 2 front.
Old Sep 2, 2004 | 10:39 AM
Asleeper's Avatar
When I release the parking brake there is some slack in the brake lever. You can pull it up a few clicks and there is no tension in the handle. When driving the brake will stick for awhile, then it will tighten back up.
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
