Wow, can't shift, and clutch pedal stuck!
Old Sep 3, 2004 | 06:10 AM
MadChef's Avatar
This is basically an update on this thread:
http://forums.maxima.org/showthread.php?t=334182
This morning, I found that I couldn't shift into any gear at all (clutch fluid level is again confirmed to be good, clutch is fairly new). Not only that, but now the clutch pedal is stuck all the way down, and it does not disengage the clutch (even down). So basically the pedal is useless.
So I had to drive the thing to the dealer...but how?
Lol, this is extremly gettho, but I turned off the car, put it into the gear I wanted (say reverse), and turned the car on, immediatly giving it some gas.
When I got to stop lights, I had to turn off the car, otherwise it was going to stall out anyways.
Well, the car is at the dealer (still don't know how I got it there), and I am completly at their mercy....this ba-lows
Any rough estimates on what you guys think this place is going to tell me is wrong? I have some scary ideas, but I am hoping for the best here.
Oh, btw, the Nissan dealer just opened a week ago, so the service people are pretty much "green" (aka they were semi-nice)
Old Sep 3, 2004 | 06:25 AM
thekenone's Avatar
possibly had air in the line from a leak. still will probably shaft you but i don't know
Old Sep 3, 2004 | 07:17 AM
datguyclark's Avatar
yea air in the line..bad pressure plate...if they try to charge you more than 5-600 for the fix be weary about it
Old Sep 8, 2004 | 02:01 PM
MadChef's Avatar
For searching purposes I'll put down what the problem was.
Turns out I needed a new master and slave cylinder. It very well could have been the hose problem (http://www.motorvate.ca/mvp.php/802), but in that case I would be leaking fluid. There was no leaking fluid, and my resvoir was filled.
Anyways, $470 later I'm all fixed.
Old Sep 8, 2004 | 02:05 PM
XeroX's Avatar
Hella internets
haha.. i was looking for that, and then you found it b4 i could even read your post lol...
damn, i gotta slow down haha!
Old Sep 8, 2004 | 07:24 PM
maxtuner96's Avatar
Clutch problem
You definitely have a master and/or slave cylinder problem. More than likely its the Master cylinder not working properly. I had the same problem a few months ago on my Maxima and I had my mechanic check it out. Turned out I had a leak in the hydrolic hose that connects directly to the slave cylinder AND the master cylinder wasn't working (the fluid stayed in the reservior). I only spent about $130 on parts and paid my mechanic a few bucks to intall it. You can change the master cylinder yourself pretty easily....no need to take it to the dealer. They're gonna charge you up the @$$! Good luck!
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
