Check Engine Light, your opinion?
Old Sep 4, 2004 | 12:30 PM
KLiNkER's Avatar
First of all, I own a 1996 Maxima SE
Ok it all started about 3 months ago, when i had the Check Engine light for the first time. I browsed the internet and found this website
http://vbxmaxima.8m.com/ecu.html
so I diagnosed it myself and found the following codes
Knock Sensor
Engine Coolant Temperature Sensor
I resetted the ECU to see if it would come back and it didn't. About 800km later, it came back. Diagnosed it again, with same codes. Reset again, not coming back until today (about 1000km later) and its still the same codes.
my guess is that if those sensors were really defects, the codes would have come back immediately, so im saying its probably something between the ECU and the actual sensors. connections or something.
any suggestions on tests to do to make sure my sensors are in good condition?
thank you
Old Sep 4, 2004 | 12:35 PM
Kevlo911's Avatar
Kevlo for President
ECTS-- replace it first. Then check the codes and see if the KS code goes away(a CEL will not be triggered). If the KS comes on too, then replace it.
Old Sep 4, 2004 | 01:38 PM
KLiNkER's Avatar
ok so what youre saying is that one of the two sensors may indeed be defect and that is what causes the second error?
Old Sep 4, 2004 | 01:45 PM
Kevlo911's Avatar
Kevlo for President
It has been known that hte KS code comes up with other codes even though it MAY not be bad. So it would make sence for you to do the way I told you to in my other post.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
