Tranny Help
Old Sep 5, 2004 | 07:37 PM
dr_blaqueman's Avatar
Tranny Help
I need a new transmission. I have a '95 5 speed and had a few questions.
1.) Will all 95-99 trannys fit my car or do I need a specific one?
2.) If they don't fit what kind of mods will i need to make?
3.) Will the dates on transmissions make a difference? (ex. 12/94 or 1/95)
I have checked car-part.com and I think I may have found a one I just have to make a few phone calls. If anybody knows of anybody who is selling one or knows where I can get one let me know. Thanks in advance for all the help.
Old Sep 5, 2004 | 07:44 PM
Terran's Avatar
All 1995-1999 as well as 2000-2001 will fit. I would (and did) go for a 2k-2k1 tranny because they have a stronger third gear, don't have the diffy bearing problem, and are about the same price but often less mileage. If you get a 4th gen definetely only get a 98-99 since they also don't have the diffy bearing problem.
Just to clear a few things up on the 5th gen tranny. You can use your 4th gen axles. You can use ALL the sensors that come on the tranny. I was told that you have to use a 4th gen speed sensor, but this is untrue. I am currently using the 5th gen speed sensor.
What happened to your tranny?
Old Sep 5, 2004 | 07:46 PM
nostrixoxide's Avatar
I'm pretty sure any 95-99 Maxima or infinity I30 transmission will work. But before you rush into replacing your tranny, you might want to check around here on the org. I think alot of people are putting the 00-01 tranny's in there car because they are a six speed. Sorry, I wish I could be more of a help to you. But i would deffinitly look into it. If you can't use the 6 speed tranny, then I would suggest a Infinity I30 trans with the VLSD option. Good luck...
Old Sep 5, 2004 | 07:50 PM
Terran's Avatar
2k-2k1 is still five speed.
2k2-2k3 had the option of six speed. This is what you are thinking of. This is NOT a direct fit, but has been done. Not recommended if you want your car back up and running soon.
Old Sep 5, 2004 | 08:18 PM
Thanks Terran, I knew someone would step up that had the correct info.
Old Sep 5, 2004 | 08:44 PM
maximagx5's Avatar
The Post That Terran Said Is The Best Info. I Currently Have A 95 Se And Have The Common Bearing Problem That The 95-97 Expreience. The 98 To 01 Are The Best To Go With
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
