Vibrating wheel
Old Sep 9, 2004 | 09:27 AM
cerumo's Avatar
Vibrating wheel
My car was ok 2 days ago when I drove the car on the freeway, got home and parked it. The day after, I took off, got into the freeway, all of the sudden the steering wheel was vibrating hard. I did'nt hit any potholes, it was just out of the blue. I can almost certain that it was the front driver side wheel that was vibrating. No dent either. I thought the balancing weight somehow fell off but they were still sticking inside the wheels. Anyone knows what might have caused the vibration? bad axles? joints?
Thanks.
Old Sep 9, 2004 | 09:51 AM
Taken2DaMax's Avatar
Try looking into the rotor. The rotor could be warped, just probably needed to be turned.
Old Sep 9, 2004 | 09:52 AM
cerumo's Avatar
thks, but does it have anything to do with the brake rotor?
Old Sep 9, 2004 | 09:58 AM
f550maranello2's Avatar
it might be your ball joints does it vibrate when you go over a bump?
Old Sep 9, 2004 | 10:01 AM
cerumo's Avatar
No, it vibrates all the time and even worse at higher speed, I would say I can feel it about >45 mph.
Old Sep 9, 2004 | 10:15 AM
its probably the ball joints or your rotors man, rotors especially when u brake and ur foot pulsates
Old Sep 9, 2004 | 11:08 AM
96pearlmax's Avatar
i still think its your front end alignment
Old Sep 9, 2004 | 12:42 PM
chuckie311's Avatar
well if he is driving im sure its not going to be the rotors cause hes not stopping
Old Sep 9, 2004 | 12:51 PM
MaxedOutOfCash's Avatar
Pizda Boy
it would be rotors if it was vibrating only when you were braking...
Old Sep 9, 2004 | 01:07 PM
joelfate's Avatar
It could just be a bad tire, I have to replace mine about every 6 months. In the 1 to 2 months at least 1 of them start to shake the steering wheel, most of the time it's the front driver side. try switching the front driver side for the back.
Old Sep 9, 2004 | 01:15 PM
robert1947's Avatar
Get it looked at right away
[Sorry Joelfate, I was drafting this while you posted your reply. We're thinking alike.]
Any severe vibration in the front end, especially one that starts abruptly, could be very dangerous. You owe it to yourself to have it inspected as soon as possible.
Another possible cause besides those already mentioned is a tire that has gone out of round due to cord material breaking or tread separation. This can happen even to a relatively new tire. If the vibration is not noticeable until higher speeds, such as 45 mph, the faulty tire may not test out of round at rest. The centrifugal force of the tire rpms at higher speeds may be necessary to pull the tire out of round. A simple test is to swap the suspect wheel (front left, did you say) with a rear wheel and see if the vibration effect is different. If the tire is bad you've got to replace it before it comes apart on the freeway and gives you more excitement than you want.
A rather unlikely but very scary possibility is loose lug nuts. Easy to check, though.
Old Sep 10, 2004 | 07:43 AM
Max96GLE's Avatar
Could it be that the tires needs to be balance? I have a similar problem when I'm driving 80 mph. When I drive 30 to 50 mph, I don't have that problem. I did an alignment a couple of months ago. I check the rims and the tabs are still there.
If you brake at high speed and the steering wheel started shaking, than is the rotor. I have that fix by resurfacing the front rotor.
Old Sep 10, 2004 | 07:47 AM
mzmtg's Avatar
Minister of Silly Walks
Have you tried cleaning your throttle body?
Old Sep 10, 2004 | 08:59 AM
KsuMax's Avatar
Cheesing away...
10char
Old Sep 10, 2004 | 02:17 PM
maximaman10's Avatar
It is probably a broken belt in your tire.
Old Sep 10, 2004 | 04:25 PM
michaelnyden's Avatar
if the car thumps ever so slightly between a certain range of speeds...usually lower speeds and then shakes at high speeds...you need to get your wheels balanced...you will be amazed how easily they can be thrown out of balance and how many people have out of balance wheels and drive on them all the time....it's just that most people's wheels are slightly out of balance so there is not shaking or thumping or anything....
when I locked up my wheels braking for 100ft one time, it threw my wheels way out of balance...the guys at the tire shop looked at my like I was crazy even driving on them (almost like they have never seen something so unbalanced)...anyway, my high speed stability was horrible!!! my car would kinda shake
if it's not that then maybe the ball joints or tie rods
user 11122324
42
Jul 18, 2022 03:35 PM
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
06maxima55
Sep 28, 2015 04:29 PM
Bonka
Sep 14, 2015 11:18 PM
