Help!!! Car Not Working Help!!!!
Old Sep 9, 2004 | 05:58 PM
ZeRo MaX's Avatar
I gotta work tomorrow.... only car...
I was cleaning my engine and stuff and i took out the battery and the intake and cleaned everything up.. i put everything back together... started the first time.. took it out for a ride... came back... turned it off... and like 2 mins later. i tried to turn it back on but it's not workin'... i've been loookin' around all nite to see what's wrong.. both the battery terminals are on tight... nothin' seems loose or anythin'... i was thinkin' maybe i sprayed the cleaner stuff into the wires and stuff... when i tried to start the car.. there's a weird sound on teh passenger side.. not sure what it is... alternator? i know it's not my starter cuz i replaced that like 3 months ago.... and i did the alternator recall so i don't know if it's that... i KNOW it DID start when i jumped the car.. but i stopped it... and it's not workin' anymore!!
help please!!
Old Sep 9, 2004 | 06:23 PM
ZeRo MaX's Avatar
electrical problem... still doesn;t work... had to jump start the car again... and park it closer to the lights.. can't see what's wrong..... even with the lights on... the car starts... only when i jump it.. but it doesn't work when i start it without the battery jump cables in.... tryin' to leave the car for longer to see if it can suck in the juice....
someone help me :-/
Old Sep 9, 2004 | 06:31 PM
ZeRo MaX's Avatar
UPDATE: when i left it there for a while ... starting... it worked when i turned it off... goin' to check in 5 mins to see if it starts again... CROSSING MY FINGERS!!!
Old Sep 9, 2004 | 06:58 PM
PoePoe2797's Avatar
Only thing I can think of is a loose ground or bad battery. Try running a thick cable from the negative to the chassis then try to start.
Lakersallday24
Jun 16, 2019 01:35 AM
ah2002
Mar 9, 2016 01:42 PM
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
