Installing K&N Filter
Old Apr 8, 2001 | 02:59 PM
SB97MAX's Avatar
When installing the filter do I just have to unlatch those 4 silver clips and lift it up or do I have to take something else off? I know this is a dumb question and should be a very simple procedure, but it is my first time doing this. Does anyone have the step by step instructions with pics or is there a place that has it on the How 2's. I know I can do it I just want to make sure I can do it right. Thanks
Old Apr 8, 2001 | 03:07 PM
ybelm620
what kind
of filter are you installing. is it a cone filter. if it is you will have to remove your stock air box, if it is a regular box like air filter just unclip the four clips and drop it in.
Old Apr 8, 2001 | 03:15 PM
SB97MAX's Avatar
Re: what kind
It is just the regular flat filter. Do I need to put those little foam gaskets in that were in the K&N filter box or do I just take the old filter out and just drop the K&N filter in? Thanks again
Old Apr 8, 2001 | 03:56 PM
GaMax97GLE's Avatar
Hmmm
I just put my drop in the other day and I didn't use thise foam gaskets b/c the filter seemed to fit snugly. Do I have to use those anyway? Thanks.
Old Apr 8, 2001 | 03:57 PM
SB97MAX's Avatar
Re: Re: what kind
Do I need those foam pads in there or not? Two came in the box. Im getting ready to go put it in so if anyone could let me know if I need those or not id appreciate it. Thanks
Old Apr 8, 2001 | 04:00 PM
SB97MAX's Avatar
Re: Re: Re: what kind
We must have posted at the same time because I didnt see yours when I posted. How did yours work without the foam peices? Did you notcie any difference from the old filter? Thanks
Old Apr 8, 2001 | 04:08 PM
96max's Avatar
Hi, all you do is just unclip the four silver clips and then seperate the top half of the air box from the bottom. It maybe a bit hard.. it may sorta seem like it is stuck, but just move it arond a bit (the top half) then you will get it loose. After that, just place the K&N drop in, into the box, then close it up.....
BRIGBOY's Avatar
I didn't notice any foam pieces.....
..but I think I have a slightly different K&N in. (This is the stock filter box). The number is something dash 2, right. I used the one without the dash - 2 in the part number. It fits very snug.
Yes the four silver clamps are all you need to unclip, then lift the top half of the box and swap the filters. If the K&N isn't sitting right the box won't close correctly.
Hope I didn't confse ya with that top part.
Old Apr 8, 2001 | 04:27 PM
Nismo's Avatar
I unlatched the 4 clips and unbolted the 4 screws that holds the upper part of the box to the TB. I didnt use the gaskets. I think they are for the I30. But now I have a cone filter.
The Wizard
24
Oct 1, 2015 08:47 PM
cruce91
Sep 20, 2015 10:23 AM
aminus21
Sep 12, 2015 04:53 PM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
