01' Trans in a 98
Old Sep 15, 2004 | 09:13 PM
AsthmaMax11's Avatar
01' Trans in a 98
Ok,
What would be different in putting a 2001 5-speed trans into a 98 5-speed rather than putting a 98 into a 98?
I am about to have my transmission replaced and would like to know which is best.
thank you
Bruce
Old Sep 15, 2004 | 09:24 PM
juani's Avatar
Rockin' VK56!!
Originally Posted by Lurchdogg11
Ok,
thank you
Bruce
nothing different, just the shifter position.
shifter will lean backward little bit
Old Sep 15, 2004 | 10:34 PM
Momaxima's Avatar
Leaan back leean back yeah ...haha ok bye
Old Sep 15, 2004 | 11:01 PM
|Bijan|'s Avatar
UCF Lexus
Bruce....it'll work. I got an 01 in mine.
Old Sep 16, 2004 | 12:05 AM
papasmurf's Avatar
Honda Convert!
So then here is the question what a bout a six speed. And then having new gears cut so they are longer that why you can hold the gear longer for the 1/4 and also for topside running.
Bruce ( Not the same guy who started this thread)
Old Sep 16, 2004 | 12:06 AM
naijai's Avatar
what about an auto transmission from an 01 to a 95
Old Sep 16, 2004 | 12:40 AM
maxS
that works too/ but with some mods
Old Sep 16, 2004 | 03:04 AM
96_vqmax's Avatar
So,what else do you need to get the 01 to fit a 95-99?Do the axle need to replace too?Thanx!
Old Sep 16, 2004 | 04:11 AM
liqidvenom's Avatar
brotherhood of tq
hmm i knew a guy who did this to his car... i have a feeling that it just bolted right up with no other changes need.
Old Sep 16, 2004 | 07:43 AM
matty's Avatar
NO changes needed..call any axle guy in the area and everyone will tell you that the 95-99' axle part numbers are the same for the 00-01'. The shifter will lean back a slight bit back but only noticable to you, and you do get used to it fast.
The drivers side axle will be different ONLY if you use an anniversary edition tranny from a 2001' Maxima which is really rair
-matt
Old Sep 16, 2004 | 07:52 AM
papasmurf's Avatar
Honda Convert!
So does anyone know about a six speed in to a 4th gen?
Bruce
Old Sep 16, 2004 | 09:32 AM
96_vqmax's Avatar
-matt
So the 01 anniversary edition tranny has lsd?
Old Sep 16, 2004 | 09:51 AM
naijai's Avatar
what kind of mods will need to be done for putting a 5th gen auto into a 4th gen i havent seen a write up or faq on it
Old Sep 16, 2004 | 10:12 AM
|Bijan|'s Avatar
UCF Lexus
No ****** mods!!!!!!!!!! OMG......you guys need to READ! Auto OR 5spd....they bolt right up.
There has been ONE 6 speed tranny (that I know of) in a 4th gen. And even he said it wasnt worth the time/money/work.
Old Sep 16, 2004 | 10:27 AM
papasmurf's Avatar
Honda Convert!
hey thats cool I'll just have to change my gear ratios to smooth out the power band and get to where I want to be.
Bruce
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
carlosvq30
Sep 26, 2015 09:44 AM
