can someone tell me where the egr valve is on 95 max?
Old Sep 15, 2004 | 09:55 PM
maximaseefu's Avatar
throw me a bone on this egr valve guys!!
I got the egr valve code and i don't know where it is or what it looks like. anyone care to point me in the direction and give me a tip on what it looks like??
Old Sep 15, 2004 | 09:57 PM
I30tMikeD's Avatar
Old Sep 15, 2004 | 10:02 PM
Originally Posted by I30tMikeD
thanks much. i used to have fsm but when i moved into my house it got lost in the shuffle. my max is now my beater so i want to invest as little money as possible into it seeing as it has over 200k on it. so any more help?
Old Sep 18, 2004 | 11:17 AM
bump. i have been searching high and low and am still not able to find it. anyone can describe what it looks like and where it is or better yet a pic???
Old Sep 18, 2004 | 12:27 PM
throw me a bone guys.
is it behind the throttle body with about 4 harnesses on it and a hose going to the intake? kinda above the fuel filter?
Old Sep 18, 2004 | 12:36 PM
bearded's Avatar
here is the picture of the haynes manual page about the egr valve. Aren't mods supposed to set good examples for everyone else??
Old Sep 18, 2004 | 12:43 PM
Thanks bearded, off to the garage again.
Old Sep 18, 2004 | 12:46 PM
datguyclark's Avatar
driver side next to the back corner of the intake manifold...unlucky for you it is a 95 like mine and is in an awkward spot...should be at least a little shiny and a copper color with 2 vacume lines going to it
Old Sep 18, 2004 | 12:59 PM
thanks to all of you and bearded's help i was able to find it........now how do i take it out and clean it???
Old Sep 18, 2004 | 01:27 PM
bearded's Avatar
Did you get the ecu code: egr hi/lo flow?
Here are some links to threads that discuss this issue.
http://forums.maxima.org/showthread.php?p=2917426
http://forums.maxima.org/showthread....nifold+removal
To remove the egr valve you need to remove the air intake duct. Then you need to detach the vacuum line that runs tothe egr valve. Next, you loosen and remove the nut the holds the valve and remove the two fasteners.
Old Sep 18, 2004 | 02:12 PM
thanks for all your help bearded. I broke down and just got back from buying the haynes manual. the code i am getting is 0306 EGRC BPT valve. wish me luck.
Old Sep 18, 2004 | 03:53 PM
crap, even with the manual it is like a freakin jungle in there. i finally figured out the egr valve is right there and the egr valve transducer is right above it. i cannot see any way to take either of these off and to top it off there is no room to work with. any suggestions?
Old Sep 23, 2004 | 10:14 AM
XeroX's Avatar
Hella internets
i ended up taking off the whole intake manifold off, cleaning it thoroughly and cleaning the EGR tube leading to the manifold. (the one thats bolted onto it with 2 bolts) it was full of Carbon buildup and i sprayed some TB cleaner in there...
I reset my ECU, and i havent popped up with the code yet.
I might have to take my manifold off again tomaorw, so i will try to take pics for you guys.. MAYBE...
Old Sep 23, 2004 | 10:50 AM
s0ber's Avatar
damn i've been itching to take that manifold off for months.. Take pics for us to see how it looks in there =) Someone should do a write up on it it..
Looking at it and all the stuff connected to it just gives me a headache
Old Sep 23, 2004 | 11:00 AM
MattMaxima_V2's Avatar
Best $16 you can ever spend for your maxima!
shilov
Feb 19, 2024 09:40 PM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
tardrex
Sep 11, 2015 07:35 PM
